skullz696969
- Nov 24, 2009
1994 ford ranger 2wd, 2.3l 4 cylinder. Sometimes it will run fine then sometimes it wants to stall when i first start it but 50/50 of the times it will only do it when the truck is warm. I know its not the battery i had it tested and i know its not the alternator because i had it tested as well. i know it could have been it because its not putting out enough voltage/amps to keep spark on the engine. so i am completely out of ideas on what it could be. bad ground? if so where are all the grounds located?
Thanks ahead for all the help.
