1993 ford ranger splash 4.0 5speed 4x4 no start
Shoaf72
NWI
31x10.50x15
Finally fixed my melting wire issue but now I have a no start issue just clicks. New battery, new terminal ends, new ground and power wire. I pulled the starter and bench tested it and it worked just fine. The starter solenoid on the fender just clicks and when I try to start it the little wire from the solenoid to the starter acts like it jumps when the truck trys to start I can pull it behind another vehicle and it starts right up.
MAKE SURE a tire is blocked and transmission is IN NEUTRAL for the following tests!!!!
There are two relays
The one on the inner fender and the one on starter motor
Inner fender relay is clicking which means it is getting 12volts from ignition switch(red/blue wire) when key is turned to START
So that part is OK
The smaller wire, on its own, on one of the larger posts on the inner fender relay goes to the "S" post on the starter's relay, smaller post, this activates the starter's relay
Use a small jumper wire from battery positive to this smaller wire, it can stay hooked up to larger post on inner fender relay
Start should activate when you jump 12v to this wire
If not the wire is bad, or its not hooked up to "S" post on starter, or starter relay is bad
If starter does activate then this wire is OK, check/clean connection to inner fender relay
If still no start with key then inner fender relay is bad, contacts not passing reliable 12v to this wire to starter
You can bypass the inner fender relay by extending the red/blue wire and connecting it directly to the smaller "S" post on starter motor, one less relay to fail
This was done on 1995 and up Rangers
Well today I replaced the starter, solenoid and clutch switch it started up but the starter stuck and now wont do anything agian
New starter = bad starter, its getting fairly common now-a-days
you think it needs another starter?
Yes, if starter stuck then its bad
New used to mean "tested and working"...................30-40 years ago
New, now means "never tested, YOU tested it, and we will replace it if it doesn't work"
Labor is expensive, so Quality Control is now a warranty, 0 testing
Shoaf,
With an assistant in the dark, try starting it, with either you or your assistant, looking in the engine bay at the starter relay, battery, cables, starter and a general, just good solid looksie at the suspect components and associated wiring.
NOTES: by "dark", I mean the least light/visibility possible. Example, in a garage, all lights off, with the garage doors/windows shut/covered at midnight with NO moon out (darkest possible environment).
