1993 F150 4x4 4.9L 5spd to Automatic
Automatics are simply stronger than manual transmissions, thats why they always have a higher tow weight rating
Yes, the low-range when backing up a trailer would be a good idea, if your having to "feather" the clutch with standard ratio Reverse gear
Also make sure to insert the pin to block tongue activated trailer brakes when backing up :)
