playaforiife
- Nov 19, 2009
- 199 ranger 2.9
- Automatic
Okay, Well having issues.
1990 ranger 2.9
i bought the truck two years ago for 4X4 reasons, snow, moving stuff, etc..
When i bought the truck, it had some issues with running, and had check engine light lit. Knowing its OBD-1 i pulled the codes myself, and corrected all the issues. No more cel! yay!
Well here we are now.. present day..
The truck wont start on its own. It just cranks and cranks. If i spray starter fluid in intake it will fire up and run fine. And continue to run. So i know the fuel pumps are doing something. just not enough. When i turn the key, i dont hear the fuel pump prime. And i think this is my issue. But why?
I replaced the in take pump two years ago when i was clearing codes, so i know it was good then. And since after i get it started she stays running thats good.
The cel is on, and i want to see what the new codes are, but it wont give any. When i perform the self test, the light just stays lit, never blinks. The computer doesnt make any of the Self test sounds it normally would.
Would a bad eec relay cause me to not be able to pull codes? would that make fuel system not prime before start up? And if i it was bad, could the truck still run without it?
i am a HUGE searcher, and have read hundreds of threads involving similar issues. Seems everyone who needs starter fluid to start, also needs it to keep truck running, with mine once it starts, she stays running just fine. And even once warm i shut it off, she starts right back up with out fluid.
I know if i can get the codes i can fix problem, but im feeling like me not being able to retreive the codes, IS part of the problem.
Just dont wanna throw parts at it, if someone has any good info for me, id be very thankful. ill check back every hour till this is resolved. ha. Any help?
THANKS THANKS THANKS THANKS!!!
1990 ranger 2.9
