1988 bronco II with 4.0 motor mount
rochhound
arizona
my bronco II has a 4.0 i put in a while back . im having a problem with the fan hitting the shroud and breaking the fan blades when im putting high torgue like a steep hill 4 wheeling. im using the 4.0 shroud and radiator. i used the stock
2.9 motor mounts! i obviously need to change these out,my question is should i go to 4.0 motor mounts or does someone have better suggestion
thanks steve
The factory 4 liter trucks have a shock looking thing on the left side, perhaps it's there to prevent such a thing happening.
I would probably just go ahead and adjust the shroud. I've been running the same mounts on the engine from the donor for 2 years.
