ducarngr
- Aug 30, 2008
- Manual
1986 Ranger with 14" rims, I want 15" (for better tire selection) -- info pls?
The offering of 14" tires stinks. I notice the later Rangers have 15" rims, anyone have info on swapping? Is this just a 1:1 swap? I don't have a lift kit in and not sure I want one and I don't need huge tires, just want slightly bigger ones.
My factory tires are 195/95R14, I was looking at some 215 or 225 tires. profile would be 65 or 70 for a slightly taller tire.
Anyone have input? yes, I know the speedo will be a little off. I am concerned about fitting under the fender and axle issues with a bigger/wider tire.
Can I use rims from a later model Ranger? Do they have the same bolt pattern?
I use this calculator to see the tire size difference:
http://www.miata.net/garage/tirecalcold.html
THANKS
THANKS
