08 FX4 transmission problem
J.stewart
North Carolina
My trucks transmission is getting to the point, it takes forever to shift, at low speed it freewheels until I lay the gas to it or put it up in nutral and then back in gear. I can put it in reverse, you can feel it go in, but then you have give it gas, it will jump when it moves, it don't do this all the time, it drives great most of the time. Would a new valve body fix it?
Welcome to TRS :)
All automatic transmissions run on Fluid Pressure, just FYI
They have clutches and brakes(the "bands" are the Brakes) inside, clutches are engaged and disengaged using pressure, brakes are applied using pressure, gears are selected/shifted using pressure.
Front pump(main pump) provides that pressure, it is at the front of the transmission and is connected/driven by the torque converters rear shaft, so pump RPMs match engine RPMs, exactly.
Reverse requires the highest pressure, 150+ PSI, if there is an internal pressure issue slow to engage Reverse(or no Reverse) will often be the first sign of that, also higher RPM shifting or slipping.
When you raise engine RPMs you are raising Front pump RPMs which increases available pressure in the transmission, which is why, in your case, Reverse then engages.
Valve body routes internal pressure via passages and valves, so yes there could be gaskets or seals that are leaking pressure internally so pressure is lower than it should be at idle or higher RPMs overall.
But it is not a "for sure" fix, it can be done in the truck so probably worthwhile to try, if trans still has issues then it will need to be rebuilt but the new valve body can be used so not a waste of money.
The sooner the better, low pressure causes clutches to slip and bands to slip, this causes alot of wear on the friction materials used in these parts, like riding the brakes on a vehicle or clutch on manual trans.
Ok thanks, kinda what I was thinking, a blown gasket letting pressure out and causing my problems.
When you drain the pan check the ATF and for any debris in the old fluid
Darker red ATF means things are "heating up" hotter than they should, so clutch and band wear is high.
Burnt smell is "too late", time for rebuild
