04' Ranger front lift springs...
subydrift
Hey guys,
So like everyone on here I'm looking to lift my 2wd Ranger. I eventually want to build it into a prerunner but that won't be for a long time so for now I just want something that will lift about 2" and give a stronger ride than stock but not be bouncy. I want to try and avoid the spring spacers if I can and go with a full lift spring. I found some made by Springtech that were a 2" lift for pretty cheap.
http://shop.suspensionmax.com/Shop/...91/vpcsid/7184728/SFV/32526/prods_per_page/96
Has anyone used these before or know much about them? Quality? Fitment? etc.
The price is right and they are a full replacement spring like I want but i don't want to buy something that is crap. I use my truck for camping alot and I do some rallying when I'm out camping and I'm sure I will take it to the desert a time or 2. No jumping or anything crazy, mostly fast dirt roads that will probably be less than smooth.
Also, is there any other suspenion companies that make and sell just a 2" lift spring for the 98+ 2wd's?
And i'm planning on using lift shackles in the rear with 2" lift ProComp ES3000 shocks front and rear with the lift springs in the front.
Thanks in advance for any help!
Robbie
This is what it all will be going on. It currently has blown stock shocks, cheap spring block spacers, and a super stiff front ride, and the helper leaf removed from the rear (all done by PO). I've since spaced down the front shocks with washers to keep them from topping out and re-reversed the shackles (much better!).
Nevermind, I moved this to the prerunner forum...:icon_twisted:
