Sdude2008
- Sep 11, 2007
- Farmington CT
- 3.0 V6
- Tire Size
- 31x10.5x15
2003 ranger xlt 222k. yesterday I noticed my gear selector pointer is off by almost a gear. In park the pointer is almost at the R etc... Also when testing it out thru all the gears I found I am missing one. I can go from Park and get reverse, then to neutral then drive, but then I only have one more after that. So I'm not sure if 2 or 1 is missing, probably 1. D drives normally and the truck does shift thru all gears automatically so the problem is just manually shifting.
Any ideas where I should start?
Also I popped a cel so I went to check it with my tester and it seems the tester is getting no power from the connector and doesn't turn on. I checked the tester in my other car and it works fine.
Thanks in advance for any advice.
