- Mar 12, 2009
- Age
- 55
- Lavergne, TN
- Automatic
- Tire Size
- 37x12.50-17
My 03, 2.3 keeps setting the CEL as well as the check gas cap light. I have tried replacing the gas cap with no change.. I'm also getting what seems to be a random misfire but the only code I'm getting when I scan it is for the evap system.
I also have to pump gas SUPER slow or it will shoot back out the filler tube. I know from older vehicles that the vent hose was usually not venting to cause the gas to shoot back out.
My questions, #1- are the evap systems more complicated on these "newer" vehicles or is it as simple as the vent hose?
#2- While I believe what seems to be a random misfire is probably on the spark side even though it's not throwing any codes for that, is it possible that the pressure backup in the evap system could cause similar symptoms?
I know these may be stupid questions but that's one way of learning, right?
