Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > 1983-2011 Off-Road & 4x4 Ford Ranger's
Notices
1983-2011 Off-Road & 4x4 Ford Ranger's Instagram and facebook are ok, but it's hard for people to follow the details of your build. Show of your trucks, or post your build threads here.
This is NOT a help forum. Post your questions in the Help Forums further down
Reply
Thread Tools Display Modes
Old 02-09-2019, 05:10 AM   #41
bobbywalter
RBV Technical Advisor
bobbywalter's Avatar
Vehicle Year: 1988
Vehicle Make: FORD
Vehicle Model: RANGERISH SORT OF THING
I use this vehicle for: EVERYTHING
My credo: it is easier to fix and understand than "her"
bobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to behold
Default
Quote:
Originally Posted by Mightyfordranger View Post
I'm only an hour from there just outside of Akron. Ill see what I can do to help Jim!! I think I have a clean 98 green tail gate that may still be in decent shape. Also I do have a 200 amp tig and a arc machine as well. I'm trying to find a decent smaller mig here soon. I do have a whole 98 single cab to rob parts from. (Its wrecked though in the front).
Post up a date when you'll be coming up and I'll do what I can to be there.
about 1.5 miles from 250 on north on 151. my truck is in the yard so you cant miss it....same one i was in last time i met you..
plan for this week is to put front axle parts/lockouts in and hot test/ load test the power-train before tearing into it. i was wanting to build a little work bench and stuff before tearing into it...garage is plain jane so any tools are welcome.
__________________
88 ranger ext cab low rider 4x4 propelled by 395 cubes of of non turbo SLOBBERIN DIESEL...BLAHHH...motating a 4l80 thats AUTHORITATIVELY turnin a ford 208 spinning 410 open dana 60s and whatever tire suits the mood that day. how ya like me now?
bobbywalter is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
Rock Auto 5% Discount Code: 29781F0E77DE4B Expires: March 31, 2019
Old 02-09-2019, 08:46 AM   #42
Jim Oaks
Administrator
Jim Oaks's Avatar
Vehicle Year: 1996
Vehicle Make: Ford
Vehicle Model: Ranger
Jim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond repute
Default
Really starting to wish I hadn't sold my chop saw and tubing bender. I need to build a new rear bumper, and reposition the spare tire.
Jim Oaks is offline   Reply With Quote
Old 02-10-2019, 06:22 AM   #43
bobbywalter
Vehicle Year: 1988
Vehicle Make: FORD
Default
theres a welder and chop saw and pipe bender here. its pipe though. so sch 40 hrew ect are materials needed...
tubing bender not too far away though. pretty sure pottsy still has one too.
mighty ford.....i work nights....12-15 hrs depending how far away and 7 days. not sure if you have my number. i am on a few phones since i last talked to a..same number though.
__________________
Old 02-10-2019, 02:16 PM   #44
Mightyfordranger
Mightyfordranger's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: broncoii
I use this vehicle for: wrenching
Mightyfordranger will become famous soon enoughMightyfordranger will become famous soon enough
Default
I work 2nd shift currently 6 days a week. I just bought a 02 ext cab to build. Its not legal yet. But I'm working on all that. I think I need to toss a clutch in it. But once its good enough to make the trip down. I can load up some welders. I'll see what I can do about bringing some DOM with as well.
One question though...will we have heat??
Also Jim check your PM box sent ya one.
Oh and I maybe able to bring some kind of a work bench as well. I'll have to score a trailer from my brother.
__________________
Doin the three pedal tango...
Mightyfordranger is offline   Reply With Quote
Old 02-12-2019, 03:37 AM   #45
Jim Oaks
Administrator
Jim Oaks's Avatar
Vehicle Year: 1996
Vehicle Make: Ford
Default
The more I think about the truck, the more I start losing sleep trying to come up with a plan. One of the things weighing on my mind is the engine. I replaced the original motor back in 2014 with one from a 1996 Ford Explorer. I have no idea how many miles are on the engine, but I know Bobby said it has a leak at the cylinder head. I haven't been reunited with it it. I plan to go out and tear in to it this spring.
Other than being stock, the motor has a Jet Performance Module and Borla exhaust.
I'm throwing around some engine ideas, and I know there are expenses that aren't listed, but I'm trying to get some idea of options and cost.:
Rebuild / Overhaul Option #1:
Engine Gasket Kit: Sealed Power Engine Kit Gasket Set 2601699 - $114
Rocker Arms: Melling Rocker Arms MR-927 - $99.00 ($8.25 each)
Timing Set: Sealed Power KT4028S timing set - $67.00
Stock Replacement Pushrods: Sealed Power RP3332 - $57.00 ($4.75 each) (5.48")
Oil pump: Melling: M128 Oil Pump $70.00
Oil Pump Pickup Tube: Melling 345S Oil Pump Pickup Tube $46.00
Total = $453.00 (assuming all of the rocker arms are replaced)
Rebuild / Overhaul Option #2:
Replacement Cylinder Heads - $500-$600 (pair)
Total = $854.00 (Replacement heads)
Rebuild Upgrade #1:
Comp Cams 49-410-8 camshaft - $295.00
Smith Bros NH54A-DD 5.550" Pushrods - $144.00 ($11.95 each)
Total = $835.00 (Rebuilt factory heads & camshaft upgrade)
Rebuild Upgrade #2:
Comp Cams 49-422-8 (or 410) camshaft - $295.00
Comp Cams 988-12 Dual Valve Spring - $67.00 (set of 12)
Comp Cams CCA-775-16 Spring Retainers - $55.00 (set)
Engine Gasket Kit: Sealed Power Engine Kit Gasket Set 2601699 - $114.00
Total = $1,357 - $1,457 (Replacement heads with upgraded camshaft)
Explorer 5.0L Swap:
Engine & Trans - $500-$600
BW4406 Transfer Case - $200
Cylinder Head Gasket Kit - $60.00
Oil Pump - $31.00
Timing Chain Set - $35.00
Timing Cover Gasket Set - $14.00
Crank Seals - $14.00
Oil Pan Gasket - $16.00
Total = $870-$970
Here's a really good deal on an engine donor:
https://tuscarawas.craigslist.org/ct...803625136.html
This assumes that the engine is in good mechanical condition and just needs freshened up with gaskets, seals, oil pump, and timing set. This doesn't include motor mounts and all the other things that might be needed?
Will also need some driveshaft mods.
I know some of you may think you should just replace everything with a V8. I've been very please with the performance of the 4.0L. I've had a 302 Ranger 4x4, and they're great for throwing mud, so I know the benefits of a V8. I want a reliable truck that I can travel all across the country in.
Anyone have any advise as to why I shouldn't just overhaul the 4.0L in it now??
Old 02-12-2019, 09:33 AM   #46
deathbypsi
06/2012 STOTM Winner
deathbypsi's Avatar
Vehicle Year: 88
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: putting a smile on my face
deathbypsi will become famous soon enough
Default
Jim I will say this since I have done three different swaps using Explorer motors as donors. In my experience I donít care what the mileage on an Explorer motor is I consider at a bare minimum the timing chain set up needs to be replaced because they are not a double roller like the early high output motors because of the shallow timing chain cover. There is no clearance and they seem to stretch badly. The other issue is the valve spring components are garbage from the factory and are junk before they are out of warranty. At a bare minimum the heads would need a good valve spring upgrade with matching components. So with considering a V-8 swap I would consider all of those as essential upgrades along with the associated parts to make that happen.
__________________
Brian R. from Mi
86 Bronco2 5.0 SAS
88 Ranger 2.6 turbo drag truck
88 Ranger 2.3t June'12 STOM R.I.P.
83 Ranger truggy 5.0
deathbypsi is offline   Reply With Quote
Old 02-12-2019, 09:40 AM   #47
deathbypsi
deathbypsi's Avatar
Vehicle Year: 88
Vehicle Make: ford
Default
I personally donít think you will have an issue whether you go V-6 or V-8 the part I question is the transmission that will have to be used with either of those engines. I am extremely disappointed with every A4LD and 5R55 that Iíve ever owned in a 4wd truck. I have spent thousands of dollars on the automatic transmission in my previous 99 ranger and it was a complete disaster and a giant waste of money. That was my primary reason for using the drivetrain that I did in my Bronco2 and built a basically bulletproof C4. In your application I think a well-built explorer trans would fit the bill but there is no way I would put a penny in or trust a A4 or 5R.
__________________
Brian R. from Mi
86 Bronco2 5.0 SAS
Old 02-12-2019, 10:29 AM   #48
85_Ranger4x4
December 2013 OTOTM
85_Ranger4x4's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
I use this vehicle for: A weapon of massive consumption.
85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute
Default
Quote:
It might be totally different but I could ALMOST get the timing chain in my '87 CV engine to jump off the sprockets by hand, it was really baggy.
I have a double roller with an Explorer timing cover. :dntknow:
One thing I would be tempted to do (so tempted I did it myself) is a new water pump along with belt(s) and tensioners/idlers. It might be filed under boring misc with the engine mounts but I thought I would throw it out since you have oil pumps listed.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0HO, M5R2, Twin-Stick NP205, 31 spline T/L 8.8 w/ disc brakes.
Check out my Build Thread
Check out my NAIAS Ranger Trip
"I have not failed. I have just found 10,000 ways that won't work." - Thomas A. Edison.
85_Ranger4x4 is online now   Reply With Quote
Old 02-12-2019, 10:59 AM   #49
Jim Oaks
Administrator
Jim Oaks's Avatar
Vehicle Year: 1996
Vehicle Make: Ford
Default
I've replaced the 4R55E in this truck, and when we got it back, the trans was bad and it came with a questionable replacement. I think Bobby was going to test drive it and see if it needed rebuilt. Not sure if there is anything we could do to beef it up.
A benefit of the 5.0 would probably be the 4R70W, and I'd likely put a BW4406 behind it.
Old 02-12-2019, 11:38 AM   #50
BlackBII
Ranger Custom
BlackBII's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
I use this vehicle for: Wasting time
BlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant futureBlackBII has a brilliant future
Default
Are you dead set on using an Auto? The M5OD is a decent transmission that is easy and cheap to rebuild.
And with the right gearing, the 4.0 is perfectly suitable for a Ranger.
__________________
89-92 Rangers are best. Fight me.
1989 Ranger build - 4.0 swap, 7.5, Dana 35, 4.56 gearing, Lockers, 5" lift, Electric power steering
1976 Fiat Abarth 131 build
1990 BII-R.I.P.
BlackBII is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
My 1994 Ford Ranger Splash 4X2mixed with a 1996 Ford Ranger XLT 4X4 BryanEstep 4-Cylinder (2000 & Older) 0 05-07-2017 04:56 PM
1996 Ranger Bumper Build aakoivu Fabrication 1 07-09-2015 12:22 PM
1996 ford ranger 2wd/with V8 Rick61 V-8 Conversion Forums 2 06-06-2014 09:34 PM
1996 Ford Taurus Engine in a 1994 Ford Ranger RangerNielsen Need Urgent Help Fast! 14 04-28-2014 01:46 PM
1996 ford ranger 2.3 2wd flip_high_up Brakes 0 01-03-2011 10:04 PM
© 1999-2018 / 959 Media LLC / All Rights Reserved
