Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Engine & Transmission Forums > Engine Conversions > 'Other' Engine Conversions
Notices
'Other' Engine Conversions All other engine swaps. Not for discussing V-8 swaps
Reply
Thread Tools Display Modes
Old 02-26-2018, 08:38 PM   #121
Motohead1
Motohead1 is on a distinguished road
Default
yea who cares if a winch is slow when it can do work all day. Its still quicker than being stuck.
Love those EGTs and the compound boost.
Motohead1 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
Rock Auto 5% Discount Code: 29781F0E77DE4B Expires: March 31, 2019
Old 02-27-2018, 09:36 PM   #122
dsltech83
dsltech83 is on a distinguished road
Default
Yeah that is awesome.
You have much BRM experience?
My brother has one I might try to put in my 93 ranger
__________________
Chase
93 RCLB 4x4 3.0 5spd 1354E 7.5, D35
Ford Senior Master Technician, Gas and Diesel
ASE Master Tech & Light Duty Diesel Certified
dsltech83 is offline   Reply With Quote
Old 03-15-2018, 11:37 PM   #123
Whitbread
Junior Member
Vehicle Year: 2000
Vehicle Make: Mazda
Vehicle Model: B3000
I use this vehicle for: work and play
Whitbread is on a distinguished road
Default
I would suggest to use a BEW, BHW, or ALH over the BRM. The BRM doesn't have a power steering pump (mk5 have electric racks) and the wiring is slightly more complicated. If you got it for free or next to free, by all means use it. But if you're paying more than $500 for it, then I'd look for other options.
The truck has been riding worse and worse lately, so I decided it was time for a mild suspension refresh. New bilstein shocks, sway bar links, and upper control arms as the ball joints were a touch sloppy. Worlds better now!
__________________
TDI B3000
Whitbread is offline   Reply With Quote
Old 03-16-2018, 05:33 PM   #124
dsltech83
Default
Thanks for the info! I’m researching using an ALH instead. They are talking about keeping the BRM jetta.
__________________
Chase
Old 03-16-2018, 10:30 PM   #125
bobbywalter
RBV Technical Advisor
bobbywalter's Avatar
Vehicle Year: 1988
Vehicle Make: FORD
Vehicle Model: RANGERISH SORT OF THING
I use this vehicle for: EVERYTHING
My credo: it is easier to fix and understand than "her"
bobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to behold
Default
your truck while towing is is slow.....
almost as slow as mine with no load...
if we were drag racing......i think you would beat me with my truck empty and your truck pulling the jeep......
i have to say that is impressive for 2 liters. but....dont see it making it 100k working like that....hell 50 k would make it a super engine...
your experience with them is good for me because i would never run over 1150 egt on an unknown engine...if i was able to look closely at the pistons i may be braver....
__________________
88 ranger ext cab low rider 4x4 propelled by 395 cubes of of non turbo SLOBBERIN DIESEL...BLAHHH...motating a 4l80 thats AUTHORITATIVELY turnin a ford 208 spinning 410 open dana 60s and whatever tire suits the mood that day. how ya like me now?
bobbywalter is offline   Reply With Quote
Old 03-17-2018, 09:10 AM   #126
Whitbread
Junior Member
Vehicle Year: 2000
Vehicle Make: Mazda
Default
I don't tow loads like that every day, but why wouldn't it live 50k? If oil temp/pressure, coolant temp, and all other vitals are kept in line, the motor will be just fine. Maybe inspect rod bearing shells at 50k, but it certainly won't be shot by any means. Might have a few percent more blowby, but nothing that would render the engine toast. My other compound turbo TDI had 55k of heavy use on it and when the car got T-boned, I pulled the drivetrain out and the insides of the motor were still perfect. All I did was put new gaskets in and it's on a stand waiting for a new shell.
1150F egt's are nothing, 1600F peak and 1250F sustained with piston cooling jets are well accepted safe numbers for pretty much any DI diesel. Drag/sled only guys will peak 1800-2000F in 1/4 or 300'. With an IDI such as your 6.5, you have to be much gentler with egt's as the heat load on the prechamber/cylinder head is much higher than a DI engine.
__________________
TDI B3000
Old 03-17-2018, 09:51 PM   #127
bobbywalter
Vehicle Year: 1988
Vehicle Make: FORD
Default
i was under the impression towing was a key component for ya for some reason... dont have too much experience with this platform...(over the last 15 years) i have done many autopsy of them though when the chance was there at the yards...and seen many cracked pistons with sub 150 k cars....i had ASS U MEed it was from the neglectful owners not changing belts on time. but with many that had obviously unlifted heads and no valve damage it was perplexing...
i got to talking with others that were happy i was dissecting things making their life easier...its why i asked you what yard....pretty tight crowd with the vw guys. they told me it was from mismatching injectors and pumps looking for power.. i expected different erosion patterns from fuel heat...interestinging any case.
with coated pistons i would see it lasting. simply watching cooling temps...more importantly oil temperature, is a great way to gauge things.
add to that the full synthetic package rotella and other super oils and life with oil squirters can really take some fire.....these are really things i need to consider. i forget about those factors.... that and the vw can take 1300-1400 sustained at sea level with stock fueling.
regardless everything will be fine untill its not....one fawk up at the line with the modified fueling and its instant pooched. i see it all too often with the d max...maxxed out guys. one injector fawks up when your into it...and your wallet is screaming for mercy.
the limits of idi are indeed dismal....but running capacity of alternative blends is the only reason i tolerate it. i am considering a dmax. maybe a mechanically injected version so i can burn heavy fuel... but thats some serious work and at least 5-6 k to get going. which is cheap for what ya would get i guess...
__________________
Old 12-18-2018, 03:33 PM   #128
Whitbread
Junior Member
Vehicle Year: 2000
Vehicle Make: Mazda
Default
It is, and I tow extremely often, just not normally as heavy as the jeep loaded with gear for a weekend of wheeling. Normally my towing loads are 2-5klbs, not 6500ish.
Just passed 18kmi on the swap so far and it's been running fantastically. First major issue popped up on friday when my FTE branded slave cylinder decided it no long wanted to be together. Got a new one from Napa and R&R'ed the trans and she's back alive quickly. But that brings me to my for sale offering.
I've decided that for what I do with the truck on a daily basis, the M5OD/1354 gearing just doesn't work for me and I want to change it. Going any shorter in the rear end gears or putting in a crawl box just aren't the correct answers either. I've decided to swap to a Jeep NSG370 6 speed and Rubicon 4:1 transfer case. That will give me a 4.46:1 first gear vs the current 3.4:1.
So my whole adapter kit, starter, clutch, flywheel, 4.0L transmission, FX4 boots/shifters, complete spare good m5od guts, spare electric shift 1354, and manual 1354 transfer case with CV front output are for sale. I figure about $2200 is a fair price for all the items together. Trans and tcase shift smoothly with no scary noises.
__________________
TDI B3000
Old 12-30-2018, 12:38 PM   #129
GJ123
Junior Member
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger
GJ123 is on a distinguished road
Default
Any chance you would consider separating?
Or, consider swapping it all into my ranger along with a TDI for a little more?
Sent from my SM-G960U using Tapatalk
GJ123 is offline   Reply With Quote
Old 01-10-2019, 04:07 PM   #130
Whitbread
Junior Member
Vehicle Year: 2000
Vehicle Make: Mazda
Default
I'm certainly up for negotiating! Shoot me an email at whitbreadperformance@gmail.com
__________________
TDI B3000
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
88 Mustang 5.0HO Swap into 94 B3000 Help! grochala V-8 Conversion Forums 5 10-29-2015 06:50 AM
88 Mustang 5.0HO Swap into 94 B3000 Help! grochala Need Urgent Help Fast! 3 10-27-2015 08:07 AM
3.0 Swap 98 B3000 to 2000 B3000 jbrooks4282 Mazda B-Series Specific 0 09-13-2013 03:08 PM
b3000 engine swap russm 3.0 Liter Forum 0 07-04-2010 07:08 PM
3.0 to 4.0 swap on b3000 4x4 CRJDRIVER 'Other' Engine Conversions 2 05-22-2010 11:26 AM
© 1999-2018 / 959 Media LLC / All Rights Reserved
