Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Non Truck Discussions > The Tailgate
Notices
The Tailgate Off-topic forum. Some posts may be NSFW / NSFK.
To post in the Tailgate forum you must be a member of the Tailgate Usergroup. Click HERE to join the Tailgate Usergroup.
Reply
Thread Tools Display Modes
Old 12-27-2018, 11:38 AM   #1
Otis413
Junior Member
Otis413's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Vehicle Model: Ranger, Edge
I use this vehicle for: Daily driver
Otis413 will become famous soon enough
Default Tire change, NOT what you think....
I've been recovering pics from a computer crash, came accross these and thought someone might like them.
In case you don't know, steam locomotives have shrink-fit "tires", with occasional re-cutting, ours last about 15 years or so before needing replaced.
These pics are from a tire change on our Shay #11 (built 1923, 90 ton class C, running weight a little over 100 tons) back in 2012
Removing the axles from Shay 11
Lighting up the heater, the same kind of equipment that's been used for this job for over 100 years. Fueled by kerosene and compressed air.
The tire comes off
The axles with hubs without the tires
I don't have pictures of the reinstall (that I can find) the tires are heated in a bonfire and slid back onto the hub, there's a flange to keep them from sliding too far, then sprayed with water to shrink them back onto the hub. All tires have to be machined within 7/64ths of an inch in diameter or less. I shoot for 5/64ths or less.
This is a pic of me machining a passenger car axle set back in 2014, the same process is used for the locomotive axles/tires.
__________________
2004 Ranger Edge Plus, Ext Cab, 4.0 SOHC, 4x4
2002 Ranger XLT, Ext Cab, 4.0 SOHC, 4x4 off road
2011 Escape XLT, 3.0L, Auto, AWD
Otis413 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
Rock Auto 5% Discount Code: 29781F0E77DE4B Expires: March 31, 2019
Old 12-27-2018, 02:07 PM   #2
Vehicle Year: 1994
Vehicle Make: Ford
RonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant future
Default
I never knew they used an inner "rubber" tire on locomotives
Neat pictures
RonD is offline   Reply With Quote
Old 12-27-2018, 02:36 PM   #3
Otis413
Junior Member
Otis413's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Default
Quote:
Neat pictures
No rubber, just steel on steel. Why they call them "tires" I don't know, but thats been the name since the 1800s. Tho some high speed railroads do use a rubber layer between the hubs and "tires" to reduce vibration on the passenger cars.
__________________
Old 12-27-2018, 03:30 PM   #4
Vehicle Year: 1994
Vehicle Make: Ford
Default
So they are held together by friction only, hot steel "tire" put on rim and then allowed to cool?
Old 01-04-2019, 04:40 PM   #5
Ranger850
Ranger850's Avatar
Vehicle Year: 2001
Vehicle Make: Ford
Vehicle Model: SWB 2wd Ranger Edge 3.0 Oxford White / Charcoal int.
I use this vehicle for: Work and Play
Ranger850 is on a distinguished road
Default
Like teeth on a flywheel
__________________
2001 Single Cab 2wd Ranger EDGE. 3.n0
Ranger850 is offline   Reply With Quote
Old 01-04-2019, 05:10 PM   #6
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
That is one big-ass lathe.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
I identify as an attack helicopter.
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is online now   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
14 to 15" wheel & tire change kimfish1 Wheels & Tires 1 06-01-2012 03:21 PM
07 Ranger SC tire size change, help please rondi General Discussions 11 11-10-2010 11:37 PM
Speedometer gears,Tire change NEILZVETTE General Discussions 3 08-13-2009 02:14 PM
tire change help? kenranger1 Wheels & Tires 1 06-21-2009 07:15 PM
Gear change for a 32 inch tire? Strokin' 6 Wheels & Tires 5 02-27-2009 09:07 PM
© 1999-2018 / 959 Media LLC / All Rights Reserved
