Different bolt pattern 4.6
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Born with a 3.0, looking for a donor V8
2WD / 4WD
2WD
Stock 2"
Stock
Doing things wrong, until I get it right.
In my search for a v8 donor for my Yard ornament I call "my truck", I have stumbled upon some info that I found interesting and I was wondering if it was true. In a different post "rjaaaa"(?) mentioned he has a 4.6 v8 in his Ranger, mentioned I had a DOHC V8 Lincoln Continental, but would need a tranny out of a Marauder or mustang. Then "pjtoledo" mentioned something about the Continentals had a different bolt pattern than other 4.6 v8's due to having to match the Taurus drivetrain and possibly having the "Vulcan" bolt pattern. Does anybody know this to be true, or is it just ass-umptions and guestimations.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Yes, IIRC the 4.6 used multiple bell housing bolt patterns.
I don't know about the Continental, but I do know it was basically a Taurus and used an A4X trans, which the Taurus and Windstar/Freestar also used.
The version of that trans used in the Continental may match a small block. IIRC the 3.8 used the small-block 5.0 pattern, and was in the Windstars and pre-DOHC 3.0 Tauruses, and that some of the early 4.6s also used the same SBF pattern.
Now this is all speculation as I have no specific knowledge on this, but I would wager that the Continental engine is using the Essex/Windsor pattern, and not the Vulcan pattern, which I believe is different.
Ranger850
4,691
Tallahassee Florida
2WD / 4WD
2WD
Stock 2"
Stock
Thanx adsm08. pjtoledo did mentioned the Essex 3.8 pattern, but that it may be the same as the Vulcan pattern. is there any info ( pictures or pdf ) that would show the bolt patterns for the bell houses.
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
This: https://en.wikipedia.org/wiki/List_of_Ford_bellhousing_patterns
Says first 2 castings(numbers F1AE and F2VE) on the 4.6l block had small block Windsor pattern
Then F3VE and up 4.6l used Modular V8 pattern
And a separate pattern for the 4.6l in Lincolns
Nothing under Vulcan but this is not Ford documents just info from users
pjtoledo
2,964
Toledo Ohio
Fords
3.0 2.3
that Wiki page also has listings for the Vulcan 3.0 pattern.
included there is the 3.8 Canadian Essex V6 in FWD. aka: Taurus & Sable plus others.
the RWD 3.8 is listed as SBF pattern.
snoranger
Professional money waster
TRS Event Staff
RBV's on Boost
ASE Certified Tech
GMRS Radio License
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
Engine Type
2.3 EcoBoost
2WD / 4WD
I didn't ask for your life story, just answer the question!
The Windsor bolt pattern 4.6 SOHC was used in the early Lincoln Town Cars. IIRC, only 91-92. They were built in the Romeo plant. (Teksid built the aluminum blocks starting in 93, and The Windsor plant started building 4.6s around 97.)
Like Ron said F1 blocks will be Windsor bolt pattern, I can confirm that. I've never seen an F2 block, so I can't confirm that.
Ranger850
4,691
Tallahassee Florida
2WD / 4WD
2WD
Stock 2"
Stock
So my 98 Lincoln Conti probably has the Windsor ( F1 ) pattern. And the F2 patterns ( 91-92 LTC ) may or may NOT match the Vulcan pattern. I knew that sounded to good to be true, Thanks pjtoledo, for the info. That quad cam V8 is probably too wide for my Ranger, even if it did bolt up, I need AC.
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
By '98 it should have the standard modular pattern rather than the Windsor pattern.
Ranger850
4,691
Tallahassee Florida
2WD / 4WD
2WD
Stock 2"
Stock
Thanks to everybody for the info, the journey continues
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,821
SW Iowa
Engine Type
V8
5.0
pjtoledo
2,964
Toledo Ohio
Fords
3.0 2.3
find someone with a Hollander subscription. they publish what interchanges. some yards use them.
the corral.net forums state the Continental has a very narrow pattern, so the "Mighty Vulcan" match is still in the game.
Ranger850
4,691
Tallahassee Florida
2WD / 4WD
2WD
Stock 2"
Stock
Hollander you say?
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Ranger850
4,691
Tallahassee Florida
2WD / 4WD
2WD
Stock 2"
Stock
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,821
SW Iowa
Engine Type
V8
5.0
Staff online
Today's birthdays
Shran
April Truck of The Month
