spoolin01
- May 18, 2010
- Reaction score
- 0
- Make / Model
- Ranger
I got this truck 3 years ago with 17K miles at 5yrs old, now 42K. For most of the time I've had it I've taken to coasting downhill either in neutral or with the clutch depressed, for fuel economy, when the hill is steep enough to maintain speed. I wouldn't say that's something that happens a lot, but a few times a week. I was told the truck was a weekend mountain toy for the first owner, and the scratches in the paint led me to accept that, though there was no body or undercarriage damage. I don't drive it hard otherwise that I'm aware of, though I tow a <1000lb boat now and then and towed a 2000lb trailer from Seattle to San Francisco when I first got it.
The clutch started going out two weeks ago - incomplete disengage with fluid loss from inside the transmission bell. Topping the reservoir helped once briefly, bleeding the system helped for a few days - no reservoir drop at all for 3 days, then lost all overnight while it sat. Finally, I just now filled and bled the system again (gravity feed, and the push pedal, release valve method) and despite good pedal feel, the clutch is barely disengaging. Just as when the lines were empty, I can't shift from neutral into any gear with the engine running, even double clutching, and the truck creeps strongly in first with the clutch in.
This is the third used 4x4 manual Ranger I've owned and only one of the others required any drivetrain work (clutch) out to 150K miles or so. That's makes me wonder why this one went already.
Just bad luck or do you think the coasting trick could be a problem?
I've got a Sachs kit on order and will be pulling things apart this weekend.
