duratec focus same engine as a duratec ranger?
12345ranger12345
ford
2.3 =[
i have an 08 xl and im looking for anything that will give it more power but i cannot find ANYTHING for the 2.3
both the focus and the ranger have duratecs and i heard from somewhere that they are the same but i would like to know for sure...
is the 2.3 duratec focus the same engine as the 2.3 duratec ranger?
thanks
eric
jimmyess333
2
Killeen TX
2.3
The Focus is a front wheel drive and the Ranger is a rear wheel drive.
Rarely does an engine designed to be mounted in a FWD vehicle share anything with one designed for a RWD vehicle even if they are the same brand and displacement.
You may(but I doubt it) get lucky with some parts like throttle body, head, and possibly some internal components.
Even if a part like the head will bolt on you may have issues with motor mounting points.
Many FWD cars will put a mounting point on the head and RWD does not.
MrE_Powers
12
st. chuck county, mo.
ford
3.0,4.6,2.8
mostly true but then you have to remember the vulcan 3.0 where the only thing different is the head gasket and exhaust manafolds
12345ranger12345
ford
2.3 =[
ahhh damn:sad:
thanks guys!
Dar70
Just trade it in for a v6 if you want more power.
12345ranger12345
ford
2.3 =[
that wont make a difference man, the 2.3 is like 142 hp and the v-6 is 152 i think
Gotta_gofast
RBV's on Boost
33
Wisconsin
6.0L Powerstroke
The base V6 (3.0) wouldn't be worth getting. But the 4.0L SOHC would be a huge difference. Not to mention, you can have this, with an extended cab and 4 wheel drive. But, I know this thread isn't about purchasing a new truck.
Doug at bamachips.com has some tunes created for the duratech 2.3L engines. Check him out. You'll have to run premium fuel in order to use the more powerful tunes. Most people have some luck with a cat-back exhaust, too. This won't provide any significant improvement, but you'll most likely gain throttle response and a wee bit of power in the upper rpms.
Bill
898
Sacramento, CA
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
The 2.3L Duratec in the Ranger is manufactured in North America. The rest are from one of several other countries, depending on the origin of the vehicle.
orangealpine
thanks
eric
Depends on what you want to do. I think all internal components can be interchanged. External stuff will interchange and you can swap heads, manifolds, etc. But computer compatibility would probably become an issue with manifold swapping and "packaging" issues might be deadly. Motor mount locations are the same, but there are mounting differences, confined mostly to the timing chain cover, but they can be swapped.
Bill
Staff online
Today's birthdays
Shran
April Truck of The Month
