Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 01-10-2019, 11:40 AM   #1
DeferenceFord
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger
DeferenceFord is on a distinguished road
Default 94 Dying while driving
Hey guys, so I’m running a 2.3, 4 cylinder, manual transmission Ranger and the truck keeps dying on me. Recently I’ve had to replace the ICM since my old one burned out. After changing it out I was given codes for HEGO being too rich. Normally I can just pop the clutch and it’ll get started again but this last time it won’t start back up at all. I need to change the starter as well, but I’ve got the part on order already. Any help/suggestions?
DeferenceFord is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
Rock Auto 5% Discount Code: 29781F0E77DE4B Expires: March 31, 2019
Old 01-10-2019, 12:48 PM   #2
tomw
Vehicle Year: 1985
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: for everything
My credo: vertical and above ground
tomw has a spectacular aura abouttomw has a spectacular aura abouttomw has a spectacular aura about
Default
There are at least two styles of ICM(TFI modules remote or distributor attached), one for manual transmissions which allows popping the clutch to start, and for automatic transmissions, which does not support push start. You may have the wrong one if this applies.
tom
tomw is offline   Reply With Quote
Old 01-10-2019, 01:33 PM   #3
Vehicle Year: 1994
Vehicle Make: Ford
RonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant future
Default
Welcome to TRS
You said "codes", what were the exact codes?
I assume you meant pop the "clutch" to start it up, lol
So has the engine started since the new ICM was installed?
And if so then with the new ICM is when the engine would die while driving, not before installing it?
A dirty fuel filter will cause engine to die after running a bit
Or a failing fuel pump
But these would tend to set Lean Codes not Rich codes, which is why you should post the exact code numbers as they can be misinterpreted since they are in binary(computerese) not english, which doesn't translate well, lol.
You can do 50/50 test, although harder to do without starter motor
Spray gasoline or quick start(ether) into the engine then try to start it
If it starts and dies then you have fuel flow issue
If it doesn't start then Spark issue
50/50
Bump starting with timing belt engines can cause belt to slip, so just a heads up, starter motor doesn't spin the engine that fast on engagement like the instant and fast crank spin of a bump start in 1st gear, try to use 3rd
I doubt that's the no start problem, just a heads up
RonD is offline   Reply With Quote
Old 01-11-2019, 09:36 AM   #4
tomw
Vehicle Year: 1985
Vehicle Make: ford
Default
Bump start best done in 4th or direct gear. The reduction gears in the power path are easier to damage with the reduction ratio being turned on its head. Fourth or top gear are 'direct', which gives the best torque from the wheels towards the engine, well actually not the best, but you have a better chance of getting the engine to spin 20 rpm than you do of having it spin 30, 50, 80 which 3, 2 and 1 would try to do. (numbers pulled from thin air, but direct will try the 'least' amount of spin per wheel turn)
My explanation may be confusing, but it works best given the amount of traction and inertia available. I have started my truck when I left the lights on in a parking lot by myself, taking advantage of a slight slope and popping the clutch in 4th. It was a last resort as I was alone, 40 miles from home on the other side of the bay. Just enough battery left I guess to run the ICM and coil, and me as the 'starter'.
tom
Old 01-15-2019, 12:31 AM   #5
DeferenceFord
Vehicle Year: 1994
Vehicle Make: Ford
Default
The codes I got today when I ran it again were;
173
222
338
Any help there?
Old 01-15-2019, 01:02 AM   #6
mtnrgr
mtnrgr's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
I use this vehicle for: Everything
My credo: My Rottweilers are my guardians
mtnrgr is on a distinguished road
Default
Code 173 is (R,M) Oxygen sensor not switching – system is or was rich – Single, Right or Rear HO2S – Fuel control
Code 222 is (M) IDM open or high or right coil pack failure – Ignition Systems
Code 338 is (M) Cooling system did not heat up (check cooling system / thermostat operation)
__________________
Driving down a distinguished road in a 3.0 5spd Ranger...an open road helps you think, where you been, where your going.
mtnrgr is offline   Reply With Quote
Reply
Bookmarks
Tags
codes 173/222/338, dying, fuel issue
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
4.0 dying Tbarnes93 4.0 Liter Forum 13 05-03-2014 01:46 PM
Dying jtroseth13 Mazda B-Series Specific 2 06-15-2010 12:59 AM
Please Help Im Dying Here 87danger 2.9 Liter Forum 5 11-24-2009 11:36 AM
Help! 2.8 dying! Sweet-85' 2.8 Liter Forum 5 09-04-2009 12:04 AM
Missing and Dying smaug6 Ford Bronco II's 2 01-17-2009 11:41 AM
© 1999-2018 / 959 Media LLC / All Rights Reserved
