Noob ? can I convert a 1354 SOTF to manual?
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
I want to revive the 4wd on my 94 The shift motor is missing. Can I covert to a stick. TIA
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Yes. By getting a manual shift transfer case. The case internals are different.
ZMan
Forum Staff Member
MTOTM Winner
406
Medina, Ohio
Ford Rangers
Engine Type
2WD / 4WD
2WD
Total Drop
4/4, bagged
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
brinker88
11/2013 OTOM Winner
OTOTM Winner
36
Williamsport, Pa
4.0L
Look at the link I posted...you can shift it from INSIDE the truck...its a bit pricey though...around $300
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
The link you posted is broken. :bawling:
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
James86
10
55381, Minnesota
2012,
Ford,
Ford,
3.0 Flex Fuel, 2.5L, 3.3 Flex Fuel
WHY DO I KEEP BUYING DODGES?!?!?
IMO the shifter sucks because...."you have to crawl under the truck"
So it's ok to get out and lock in manual HUBS before you hit a mudhole, but you wait until you're ALREADY stuck in the mud to shift into 4WD and complain about crawling under? IT'S ON THE WAY TO THE FRONT OF THE TRUCK!!!!!!!:icon_rofl::icon_rofl: Just lock everything in BEFORE you hit the rough spots, or, as the forum discussing it says, carry it as a "just in case" for if your motor fails on the trail. It doesn't seem to be intended for a fulltime permanent solution.
Or....
Just get another junkyard motor. The tech library shows how to take one apart and clean it good as new....
http://www.therangerstation.com/tech_library/TCaseshiftmotor.htm
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,817
SW Iowa
Engine Type
V8
5.0
Walking thru mud isn't the same as crawling thru it. Besides that you can run it from inside the cab.
No need to have as a spare, you can manually turn the shaft that the motor usually turns. Just remove the motor and turn the shaft.
James86
10
55381, Minnesota
2012,
Ford,
Ford,
4.0B2
TRS Banner 2012-2015
151
Walls, MS
4.0 v6
i like that shifter cable thing in the link.. to bad i'm not paying $300 for it..
Staff online
Today's birthdays
Shran
April Truck of The Month
