Bucking misfire no cel
mikes02ls1
3
Casa Grande, AZ
I’ve read that on the 95 Ranger 2.3 manual trans that when driving and over the 3k rpms it’s like hitting a wall. Stumbling misfiring and bucking, no codes. I saw a tsb bulletin on the camshaft synchronizer, y’all have and symptoms like this? Where is it located?
pjtoledo
2,959
Toledo Ohio
Fords
3.0 2.3
what year and engine do you have? a 95 2.3 Lima? we aren't sure because this is the 2001 and newer 2.3 Duratec section.
Dirtman
Former Middleweight Moss Fighting Champion
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
I poop in the furnace.
When an engine runs fine to a certain point and then suddenly falls flat the way you describe is often related to a fuel delivery issue. Clogged fuel filter being the primary suspect.
mikes02ls1
3
Casa Grande, AZ
Just replaced fuel filter with a wix filter 4 days ago. Fuel pump replaced a year ago.
mikes02ls1
3
Casa Grande, AZ
Anybody replace their camshaft synchronizer on their 1995 2.3 Lima engines? If so where’s it located? Google doesn’t help.
Dirtman
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
Hook up a vac guage. Do an exhaust restriction test and a valve timing test (youtube vids on both) this will tell you if its a cam issue or another possibility, clogged cat.
mikes02ls1
3
Casa Grande, AZ
I deleted the cat already, so I’ve check that off the list.
Dirtman
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
You mentioned you pulled a P1445 code, this truck has obd2 not obd1?
Staff online
Shran
April Truck of The Month
