caliskier
- Dec 31, 2007
- Reaction score
- 0
- Make / Model
- Mazda
I just replaced the bearings in my 94 B-3000 and noticed that after putting the rear seal back in over the larger bearing that the bearing sits in there loose. I have the rotor face down on the ground, the seal is tight but the bearing can move back and forth, i.e. I can pull it out some from the race untell it bumps into the seal. I did not know if that was normal. When I put the rotor on the spindle, and pack the smaller bearing on the front and put the washer and bolt on it seams to fit fine, but I just didn't know if I installed that larger rear bearing correctly. Can you help?
