rangerbum
- Apr 22, 2008
- Reaction score
- 30
- Age
- 32
- Location
- Kalispell, Montana
- Make / Model
- Ford
- Engine Size
- 2.8l
I have searched the last couple days and haven't found the solution, but As the title states, I just swapped my cluster(from tachless to a tach equipped cluster) and the temp gauge doesn't work with the new one in.
I personally pulled the new one from the jy, it was the same year truck, with identical options other than cab size. Same motor, no ac, 2wd, 3.73 rear.
When I turn the key, it makes the initial move off the bottom Peg as it should, but as the truck runs it goes no further. All other gauges work perfectly.
Does anyone have any ideas where to start? I'm sure this can't be the first time.
