Junk Collector
- Mar 4, 2008
- Reaction score
- 4,704
- Location
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
Starting fresh with a new build thread on this one. I picked this truck up in December 2020 and haven't had time to do much with it. My 16 year old wants to drive it so I said I'd help him fix it up. Plan is a manual transmission swap, Duraspark swap and not much else, just fix all the major problems. It is kind of a basket case. Beyond the rust mentioned below, it was full of mice and everything was just very dirty.
It's got a 2.8, A4LD, and the newer column but it has a single column of warning lights. I picked this up from a friend of a friend, sight unseen, for next to nothing... I was told ahead of time that it was "very, very rusty" and it was parked a long time ago because the front seal in the trans failed. The owner let it sit with the intention of fixing it but by the time he got around to it, the driver's side floor had a basketball size hole in it. The rest of the body is actually in really good shape, a little rust over the rear wheel wells is all. I cut floor pans out of another cab so I should be able to fix it pretty easily. May see if I can get the A4LD functional or manual swap it, not sure yet.
Anyway as I said this has all of the XLS trim that the previous truck did, plus a leather wrapped steering wheel and a weird upholstered upper dash and dash compartment. I have not seen the upper dash upholstered ever, kinda weird to have carpet up there. The seats are in super nice shape and it has the roll-up center console, although the roll-up part is broken like the other one I have. Odometer shows x05000 miles... judging by the lack of wear all around, wouldn't shock me if that was actual mileage.
Pics from when I got it:
