Well it seems no-one has this cam in stock, even Comp Cams alone :-/
I will check with local grinding company if they can make a cam for me according to the Comp Cams specs.
I checked with Comp for a 390 cam I need and they have nothing in stock for that either.
I got a cam for a 2.9 I built a couple years ago from Camcraft, maybe they're worth a call. Their tech line is 828-681-5183 and order line is 800-426-2261.
We have a selection of cams for most engines found in the Ford Ranger & Bronco vehicles. This is a small listing of profiles we can grind for these vehicles. If you want something different we can probably do it. These cams are ground on new castings or billets in the case of steel roller...
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
