Ak_Ranger
- Sep 23, 2007
- 0
- Ford
- Engine Size
- 4.0
I have done some exhaust work on my truck and have been thinking about replacing all the pipe fromt he cat back. Atm I currently am using the stock piping then makes a turn out the side behind the cab with the stock 2 inch pipe. Im thinking about getting new pipe and then run the new pipe from the cats strait back then make the turn out the side like it is atm how ever I want to go to a bigger pipe. I am just wondering if I should go with 2.5 inch or if it would be alright to go with 3 inch or will 3 inch be to big?
Also If any one in here knows where to buy stock piping in Alaska please let me know. Im going to try to call Weld Air in wasilla and maby Napa and shcucks in Wasilla also.
Atm my current exhaust system is leaking and I can not weld the leak because I cant reach it. With the set up im thinking of doing I would pre weld the piece before it goes in the truck then cut the old pip off about 2 inches after the cats and use an exhaust clamp at that point then cut off the old mounting points behind where the muffler us to be then Weld those onto the new pipe to hold it in place, that way I can make sure there are no air leaks. Im new to welding so its not the greatest but so far the welds I have done have been holding up lol just cant reach that one spot thats leaking and it bugs me.
Atm I like the sound of the strait pipes after the cats I just want to try to get rid of the exhaust leaks without paying a muffler shop to do it all, and figured while I was at it might as well go and put in bigger pipe and Tip.
let me know what you guys think.
PS The truck is a 94 4.0L 5 speed Ranger.
