wont shift back in overdrive
GaryStanton
milton pa
ford ranger
I have a 93 ford ranger 4.0 automatic. When its hot out or i take a longer trip my truck shifts down out off overdrive and won't shift back up. I have to drive at 55 running 2500 rpms. After the truck cools everything is fine again until like I said take a long trip but it does it more when its hot outside. I have tried looking it up but can't find a answer and its not throwing a code. Really hope someone can help me out thanks.
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
Sounds like the 3-4 solenoid is failing after it is heat soaked. Pretty common.
GaryStanton
milton pa
ford ranger
ok were is it located and how hard is it to change its not inside the transmission is it and thank you for replying
Transman304
43
Morgantown WV
Chrysler PT
2.4
It is located in the transmission and will require removal of the valve body to replace.
GaryStanton
milton pa
ford ranger
ok thank you very much
No members online now.
