Wiring Oem foglights to a Non foglight ranger
2001FORDRANGER
Sacramento Valley
6cy
hey folks i have a 01 ranger/06 front end complete with bumper/grille including foglights, my ranger did not come with foglights, how would i go by wiring the fogs, thanks please be detailed. thanks
chvlfrk
December 2010 STOTM Winner
MTOTM Winner
31
Niota, TN
Ranger XLT 5.0L
5.0L
235/70R15 front / 275/60R15 rear
This should help ya..........
Posted this on FRF, but here it is again:
Original_Ranger84
20
2.8L, 3.0L
Or if you have the wiring they should just hook right up. Under your truck by the bumper there should be a plug going into a double socket and the unused socket i believe is for fog lights. as for the button to trn them on you need to find a ranger that did have them on it and take the radio bezel out and use the existing plug that is either connected to nothing but attached to the old bezel or just sitting in the empty space. and plug the harness into the fog light slot.
I'm not entirely sure thats correct but on mine thats how i did it.
2001FORDRANGER
Sacramento Valley
6cy
HAHA this guy is following me, nah thanks again, but man taht stuff looks foreign to me, lol
i dont know if i have this empty socket you speak of, i will be checking it out , so are you saying that in the fusbox under the engine hood, i have the wiring already installed including the fuse , lmk im a little confused,thanks!
backroad101
4
4.0L OHV
My 99 was prewired for foglights
Original_Ranger84
20
2.8L, 3.0L
No no... not in the fuse box in the hood. Although now that i think about it you will probably need a relay for the power distribution box as well.
If you go to your front tire on either side, look on the inside of the fender should be right inside the bumper up a little bit. I can get a picture later but heres approximately where it is at, there is one on both sides.
2001FORDRANGER
Sacramento Valley
6cy
okay i will check tomorrow. i am in the process of spraying, im waiting for drying than i will shoot my clears than i will check.
backroad101
4
4.0L OHV
Here is what I got for my 99
OEM left and right foglight new - ebay
OEM foglight lower valance new - ebay (does not fit just right)
OEM foglight switch used - ebay
Wires from lights to plugs mounted to frame used - junkyard
2 relays (same part # as horn relay) new - Oreilly's
radio Bezel to accept OEM foglight switch used - junkyard
I actually bought a few bezels and went with the one that looked the best. I got one bezel and switch off eBay, the rest were from the junkyard.
The bezel I ended up using was actually from an Explorer. I had to swap over all the switches from my bezel, the 2WD/4Hi/4LO indicator (since the Explorer had a differnt 4wd system), and had to pull out the rear wiper switch (and paint it's indicator) and replace with the power socket. Only thing is that I ended up with a non functional rear defrost button.
mleega1
LAGRANGE,GA
FORD
Any one know where they would be on an 06? I have the plug in in the radio bezwl, just can't seem to find the fog light pig tails......
backroad101
4
4.0L OHV
Junkyard or LMC
