Wiring harness troubkeshooting
dickjones87
EMT / Paramedic
1701Rangerdanger
Ford ranger
I got my hands on my first vehicle and it's a 94 Ford ranger 4.0 standard.
The last owner did a compression test without removing the spark plug and set the wiring harness on fire.
It's small localized.
My question is. To replace the harness do I need to remove the radiator?
Thanks for any help.
lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
8,062
Butler, PA, USSA
5.0l
4”
No, if the fire was just on the engine harness, you may have to remove the upper intake but that should be about it. The harness that runs along the core/rad support is the lighting harness, which actually can be removed by just unbolting the fan shroud and shifting it against the motor then pulling the two bolts at the top for the radiator and lean it back towards the engine.
I’m gonna move this to the 4.0 forum…
RaceRanger97
December Truck of The Month
Vagabond Video
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
