Head lights will plug right in. Then then connect the marker light wires to the brown and black wires of the 97 turn/park plug, the turn/park light wires in the 98+ pigtail should match up color wise.
Brown=marker/park light
Black= ground
Green=left signal
White=right signal
thanks the headlights did plug right in. k so the light thats also in the headlight housing and the turn signal should be wired together right? also what bulb do i need for the one in the housing?
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
