Wireless Routers
robertc1024
133
San Marcos, TX
nada
Ok Gents, I've got an ancient Netgear g router. Some of our family's devices are n. I also need to have the network reaching out to our poolhouse. Here come the questions:
1. I understand that if you have an n router and g devices slow it down to g speed. How much is it a PITA to hook my n router to the cable box and plug my g router into it?
4.0B2
151
Walls, MS
4.0 v6
idk what you're asking?
you want to go from your cable modem--to the n router-- to the g router? i don't understand? get a good N router or N+ and see if that will work distance wise for you... if not they make relay stations
http://compnetworking.about.com/od/wireless/ss/wirelessgear_7.htm
i've never used one.. i get the distance i need out of my router. if you're buying one i suggest a dual band. i have the netgear n600 dual band, we run 2 xbox's and several laptops and don't have any issues. we also have 12 meg internet tho...
buy a good router is my suggestion
Loud Ranger
5
MN
'95
i have a netgear wireless n dual band and it has 5ghz for N and a dedicated 2.4ghz band for wireless g so you can have full speed wireless n and a separate band for g. You can also set it to have G+N share the 2.4ghz for certain devices that support N but only at 2.4ghz. It doesnt slow it down to G speeds but its slower than 5ghz wireless N and more susceptible to interference.
And no you cant run a router behind a router Unless your setting it to use as an access point and not a router. which you might want to think about if your signal wont reach to the pool house.
Rockstar04
Northern Illinois
Actually you CAN have a router behind a router, it just takes some extra setup.
First you need to get into your secondary router and turn off the DHCP service, then use a crossover cable from one of the LAN ports on router one to a LAN port on router 2.
This can actually be a better way to go because you can lock your new router in N only (so no slow down for new devices), and have the second router in G on a different channel so you have less cross talk between the two access points.
This is how I have my network set up.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
I have a Linksys that does the same thing. Great little unit!
Loud Ranger
5
MN
'95
That is what i meant by using it for an access point.
Rockstar04
Northern Illinois
AAAAA Missed that first read through, I kinda stopped reading after I saw you cant do it. . .. sorry
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
I run my Netgear N router "Behind" my Cisco "gateway"
The Cisco box is both a WIRED router and my "Vonage Device"
for my VoiP phone service, but it has no WiFi and it MUST hook directly to the cable modem
AD
Loud Ranger
5
MN
'95
AD
I have the same type of device for boosting sprint cell service inside my house called an airvana. You can actually put them behind a router but you have to login through the default gateway and match all the dhcp settings to your router so everything is in the same ip range. I tried hooking it up directly to the modem like its designed to but it was killing my upload speeds and double my ping delay so i had to put it behind the router.
  • ryan
    Forum Administrator
