1up
- Feb 27, 2008
- 5
- So. Calif
- Ford
02” 3.0 gas. I recently installed a new fuel pump, and the engine will not start. It has spark and fuel pressure 60psi. I have replaced the fuel filter, drained the tank and added new fuel,disconnected the fuel line to the injectors and pumped out about 1 liter of fuel. I removed the 3 easy to get to injectors and ran carb cleaner through then to verify they were not clogged (I was lazy and figured the motor should at least try to fire with 3 clean injectors) nothing. It will fire with stater fluid but dies once that has burned off. Without starter fluid it just cranks and doesn’t even try to fire. Any ideas???
