2.3L ('02-'11) will not idle
maverick9611
augusta georgia
ranger xlt
2002 ranger 2.3L
I have mid range, top end power. super unstable on botton end
so far i have changed out
pcv valve and hose.
fuel filter
idle air control valve
mas sensor
i did findvacuum line disconnected it plugs into some valve right next to firewall directly inline with intake manifold.
has me baffled
maverick9611
augusta georgia
ranger xlt
changed out upstream o2 sensor, no change. will try egr valve next
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Did you plug the vacuum line back in? Check for other vacuum leaks? Stop replacing random parts!
alwaysFlOoReD
5,088
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I've never worked on the 2.3 but the vacuum line that was unplugged sounds like it for the FPR = Fuel Pressure Regulator. If the diaphragm of the FPR is ruptured then there will be excess fuel getting into the combustion chambers. Its a cheap part, change it.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
There's no fuel pressure regulator on an 02 2.3, it's a returnless system. The vac line he's referring to could be the IMRC solenoid or pulse dampener.
The IMRC (intake manifold runner control) system is prone to issues especially vacuum leaks and theres a plug on the intake manifold that is known to simply fall out. The fuel pulse dampener is not actually vacuum controlled even though there is a vac hose on it. The vacuum hose is just there in case of catastrophic failure the fuel will be dumped back into the engine. The dampner could fail and you wouldn't really notice any issues, if it leaks you'd get a rich code, with the line detached however you'd obviously get a lean code.
maverick9611
augusta georgia
ranger xlt
of course i plugged it back in
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
You never know. :icon_rofl:
I'd start by doing a complete vacuum leak test. YouTube has plenty of good videos for various methods. First is just to start with a visual inspection though. Your symptoms sound like a vac leak. Under mile-high throttle there is less engine vacuum so leaks become less of a problem then they do at idle and low rpm.
maverick9611
augusta georgia
ranger xlt
ok, sounds good. where is this plug on intake that i need to look for? is their a map of vacuum lines for the 2.3?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I'll see if I can take a pic of where the plug is. As for the vac lines it's fairly simple. Egr is not vacuum operated and only one line to the hvac controls. Brake booster, fuel dampner, pcv valve, and imrc solenoid are all on one fitting at the rear of the head. Evap purge solenoid is on the driver side fender, fresh air side of the pcv is on the valve cover, and hvac line is on the throttle body. I'll see if I can find the schematic.
maverick9611
augusta georgia
ranger xlt
i found one on autozone.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
None of that is right... even a little bit...
I'm actually very confused by that because none of those engines apear to even be ranger engines... the 2.3 diagram is completely wrong either way. It's not even correct for the older lima 2.3.
maverick9611
augusta georgia
ranger xlt
maverick9611
augusta georgia
ranger xlt
did you find that pic of the plug?
maverick9611
augusta georgia
ranger xlt
stumbled onto this vid. sounds similar to my problem
maverick9611
augusta georgia
ranger xlt
gettin ready for compression test, found cylinder#1 spark plug well full of oil. this could be my misfire. if compression test passes, i will change valve cover gasket to stop oil leak.
