Will a 4.0 from a 1998 explorer bolt up to my 88 bronco 2?
Pbheadshots
Shelby, NC
1984/8 mix
2.9
Not sure if the motor mounts ever changed, and is engine is coming fully complete with harnesses minus clutch, flywheel, starter, and radiator. I need to know what else I'm looking at having to add to get it running
kryptonitecb
19
Fort Worth, TX
Seems like pirate had to many Tuesday's so they migrated over here.
Sent from the road while ignoring traffic
scooter
October OTOTM Winner
50
N.W. Oklahoma
5.0L
Oooo yeaaaaaaa!!! (/kool-aid guy voice)
AngryLepercon
39
Maryland
This thread reminded me that its Tuesday.
armadillon
12
Austin, TX
Explorin94, you're on top of things with the search link! I think you've beaten the rest of us almost every time for the last 6 threads like this.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
I try....it drives me nuts to the point I just want to yell. But we all know that will get us anywhere.
Pbheadshots
Shelby, NC
1984/8 mix
2.9
Thanks assholes, Ive already searched this, I can't come to the absolute conclusion if the 98 explorer x or e series 4.0 will fit the b2... figured someone here would know but of
Course you send me the route I first took.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Well right back at you.....when in your first post did you say that you searched? Cause if you did you wouldn't have just posted what you did. A 98 4.0 is a pushrod motor which is no different from the rest. Search again there are plenty of post out there. If not then see ya later!
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Of course it'll fit. The wiring is where you will have fun. There was a kid that put a 96 4.0 in a 84 b2 on here somewhere. He was from Coweta,OK. He used the dash and everything.
The reason 91-94 explorers are the popular swap into a gen 2 B2 is because its plug and play. Its simple.
Once you go out of that realm, it starts getting a lil more difficult. Anything can be done with enough time and money.
It'll work. A SOHC will not fit, an OHV will.
The worst thing about that year will be the wiring because it is after the change to the new style cam sensor.
Pbheadshots
Shelby, NC
1984/8 mix
2.9
Quality post, thank you.
snoranger
Professional money waster
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Thanks assholes
Thats the way to get some help. :icon_thumby:
Vin "X" is the OHV. Thats the easier one to swap in, if fits a LOT easier.
During '98 they switched to a returnless fuel system, you could have either one, keep that in mind. A return style engine will work with the fuel system in your '88 without modifying.
Here's the best place to look:
BII Engine swaps forum
