Will a 2.8 distributer work correctly in a 2.9?
87dytnajeff
I was out mudding at a friends place and landed so hard the firewall shifted forward and cracked my Cap and broke off my ignition control module off the distributor. :annoyed: i have a 2.8 parts truck and i was curious if the distributor would work.
Thanks
stegomon
20
auburn/minot maine
fords and only
2.8 has a vacuum controlled advance, 2.9 is all electronic. There is no where for the TFI and pickup to mount.
Unless you did a lot more damage than your post lets on, sounds like you just need a new cap and TFI anyway, that isn't that expensive.
Mudhound
Eaastern Ky- out in the woods ( literally)
87
173 and 331 CI
The 2.8 in my 84 BII was a TFI from the factory, but still, NO it won't interchange exactly as the 2.8 turns opposite the other v6s'. The 2.8 with the Dspark were vac. controlled, however.
TheOne
Edmonton, Alberta
well if u pushed ur firewall into ur dizzy i be thinkin u should have bigger issues then a broken dizzy...but i could be wrong
1mean02hd
Chase, MD
5.0L V8
Sounds to me like you might have broke a body mount or 2
