It's cool , like I said I never used a forum in my life . I did search , and found a lot if good info , basically was wanting to know if everything would as far as wiring goes would be the same or at least simple to swap , I understand that the block and all is same but was not sure of other components , and really prob. every question on here has been asked several times , time and time again . I did see where it said the intakes were changed that's primarily the reason I asked , does that mean that it will not work or can I use that intake in a 93 . Or does the intake need to be used from old engine . These are the things I do not know and either could not find , or didn't know how to find in other post . Any info is appreciated , not trying to bog you down with repeat questions , I will look again to see if I can find the info I need .
