Depends on what clutch/flywheel you used. If it's from a 2.9 the starters are the same. If you "upgraded" to the 4.0 clutch/flywheel you'll need a manual starter from a 4.0.
BTW, later models (Not sure how much. Any 4.0 maybe?) auto starter fits the 2.9 clutch/flywheel and is of more compact design. I used one myself.
I changed my 1990 Bronco II 2.9L from an A4LD auto to the FM132 manual (2WD version of the FM146), and the auto starter was the same as the manual starter.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
