while I'm replacing everything else
97ranger22bronco
62
Dallas, TX
With the truck sitting in the field for 14 years, should I replace the master cylinder and booster on general principles? Or is it one of those that can sit for a long time and be OK? I will say that the system is completely dry and there's no fluid in it..
RobbieD
2.9l Mafia
4,497
Georgia
If it were me, first I'd put fluid in the master and then see what I've got.
In general, if the brake system is completely dry, then "yes", replacing ALL of the parts used to be the norm.
BUT, since replacement parts are such garbage these days, I wouldn't get rid of an original part until it's been proven to be failed beyond repair.
That's just me; "your mileage may vary", etc. . . .
alwaysFlOoReD
6,033
Airdrie, Alberta, Canada
'06, '11
Dodge, Ford
5.7, 3.0
If there was no leak in the system there would still be fluid in it...
19Walt93
4,948
Canaan,NH
351
3"
235/55R16
If the brake fluid is still light colored the master might be OK, if the fluid is dark colored I'd replace it, along with all the hoses, wheel cylinders and calipers. Hoses that old should be replaced regardless if it was driven everyday or not and the hydraulic pieces are cheap insurance.
97ranger22bronco
62
Dallas, TX
There's no fluid in it :cry: I'm replacing wheel cylinders, flex hoses etc. as part of maintenance process
superj
3,856
corpus christi, texas
ranger edge
182 ci of tire shredding power
2, so far
235s
drives a stick shift ranger
Dang. You might have rust inside lots of stuff
97ranger22bronco
62
Dallas, TX
that's what I'm afraid of..
Truck of The Year
Kirby N.
2024 Truck of The Year!
Vagabond Video
