Which year Rangers had aluminum hoods
Garth Libre
110
Tennessee
Which years had aluminum hoods and are the hinges the same?
2drxploder
434
usa
ranger
347
lower
235 on 15s
pjtoledo
2,963
Toledo Ohio
Fords
3.0 2.3
my 2000 does, hinges look identical to the steel 2005. 'cept maybe the ground strap.
rubydist
855
Denver
Ford Ranger FX4
They didn't all have the same construction even in a given year. For example, the 01-04 "power dome" hood on the high trim 4.0 sohc trucks were smc/fiberglass but others in that year range were steel or aluminum. But I believe the hinges were all the same.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
1998 was the first year to see an aluminum hood.
sgtsandman
Aircraft Fuel Tank Diver
12,637
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
My 1998 had one. My 2011 does not. The ‘98 was a four banger whereas the 2011 has a V6. The hood profile is also different. So, that may be why one is and the other isn’t.
JoshT
1,732
Macon/Fort Valley, GA
My 99 has one, I can tell because the paint is coming off. Ok, I could tell anyway, but it's annoying me that the paint is coming off. It's not going to help resell value, but I also doubt its worth a repain to sell.
I wonder which would sell the truck better, factory hood with the paint chipping off, or black fiberglass power dome hood that also parobably needs repaint.
Garth Libre
110
Tennessee
I hood is the easiest part of a car or truck to paint (that and a trunk which a truck doesn't have). Easy to sand, prime and paint. You can even take it off and paint it in a tent.
2drxploder
434
usa
ranger
347
lower
235 on 15s
On the topics of hoods, where could a guy find a small cowl hood for a 99 Ranger these days?
JoshT
1,732
If I were going to paint the hood, I'd need to paint the whole truck. The paint is pretty well shot and painting just the hood would stick out like a sore thumb. At a minumum, the hood, the roof, and the top part of the bed need paint. Hood for the reasons mentioned. Roof due to sun damage. Bed rails because they were sanded down for an over the rail, spray in bedliner that has since failed and mostly peeled off.
