Which Ranger should I buy?
Ranger_XL
New member
16
Wind Gap, PA
Ranger XL
1995 Ford Ranger Regular Cab XL -- 3.0 Vulcan V6, 5-Speed, Manual Transmission, 4×4 with Manual-Transfer Case and Manual-Locking Hubs, Manual, Window Cranks, 184k Miles, $2,900
1996 Ford Ranger Regular Cab XL -- 2.3 Lima I4, 5-Speed, Manual Transmission, 4×4 with Manual-Transfer Case and Manual-Locking Hubs, Manual, Window Cranks, 160k Miles, $2,000
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
alwaysFlOoReD
Forum Moderator
1,300
Red Deer, Canada
'91, '94, '80
Ford, GMC
4.0,4.0,350
My personal inclination would be the I4 for slightly better fuel mileage. The 4x4 I4 is somewhat rare but that doesn't up the value any.
4x4junkie
Forum Moderator
251
So. Calif (SFV)
2.9L V6
35x12.50R15
Both seem like good deals to me. The 2.3L 4x4 trucks are rare birds.
The 3.0L truck will have a better front axle under it (larger differential & gears with more aftermarket options available), though the one under the 2.3L truck can also easily be swapped with one from another truck. The 3.0L will also have better power, but of course with a small MPG penalty.
Welcome to TRS.
r1ch999999
Active member
27
Nashua, NH
I had a 95, nothing but electrical issues. It was a 2.3 4x4 regular cab. I think it had a lift as my tailgate was higher than most f150s. If it wasn’t for the electrical issues I would have kept it longer.
I’d get the 4cyl
Forum Moderator
2,719
SW Iowa
What are you doing with the winner?
sgtsandman
Professional Wrench Bender
Forum Moderator
1,496
Aliquippa, PA
2011 & 2019
Ford XLT & FX4
4.0 SOHC & 2.3 Ecoboost
31X10.5R15 & 265/65R17
I sniff fuel for a living. Don't judge me!
It depends on what you are going to be using it for. If just on the street, the 2.3 will be fine.
Also, which one is in better shape? There is a lot of unanswered things behind all this.
Saddle Tramp
Active member
153
Florida
+1 on what are you going to use it for.
Do you plan on any towing with it? Will you be going on any hunting trails with it? Which one has less rust?
racsan
Well-known member
427
central ohio
1994 (mostly)
2.3/140-4
built, not bought
Id go with the 4 cyl. Its a little less money & has less miles, newer body too. compare normal problem areas like rear spring hangers and front core support, cab mounts. neither is a bad choice but the 4 cyl would be my choice if both are in good shape rust-wise.
wildbill23c
Well-known member
216
Southwestern Idaho
Ford Bronco II
205/75-R15
19K, 19D, 92Y, 91F
As much as I'd like to say get the one with the V6, I'd really go for the 4 cylinder 4x4...don't see them around very often.
Dirtman
Clam chowdah!
EMT / Paramedic
4,580
Over there --->
466.63 teaspoons.
So friggin big!
Give me money.
Not that much difference in power between the 3.0 and 2.3...
I'd go for the 4 cylinder as well, cheaper and less miles. Given the condition of the two trucks is fairly even in other aspects (rust).
Ranger_XL
New member
16
Wind Gap, PA
Ranger XL
I have a 2003 F-250 Super Duty Super Cab with a 6.8 V10, ZF6 (6-Speed, Manual Transmission), 4×4 with Manual-Transfer Case and Manual-Locking Hubs, and XL Trim (Window Cranks, Vinyl, Bench Seat, and Vinyl Flooring). Any towing, hauling, or otherwise heavy moving could be accomplished with that; seeing as I am daily-driving a V10, I am looking for a truck strictly to commute to work roundtrip (16 miles) and to accomplish local errands on the weekends while still having the option of four-wheel drive if needed. Towing, driving in inclement weather, general driving for pleasure, and camping trips with the wife would be done with the F-250. The 2.3 Lima 4x4 is in excellent shape admittedly; however, I have also found RWD examples with all three of the engine options (2.3 I4, 3.0 V6, and 4.0 V6), but I figured the 4×4 is worth the slight penalty in MPG rating, as it is better to have it and not need it than to need it and not have it.
Josh B
Well-known member
383
Oklahoma
Haha, I think you just answered your own question ;)
Welcome to TRS btw :)
Uncle Gump
Forum Moderator
1,842
Plano IL
Lead, Follow or get out of my way
Sounds like the 4 banger truck is a steal...
Welcome to TRS...
Saddle Tramp
Active member
153
Florida
Thanks for giving us all the info.
I'd definitely say go for the 4 banger. It'll be perfect.
Dirtman
Clam chowdah!
EMT / Paramedic
4,580
Over there --->
466.63 teaspoons.
So friggin big!
Give me money.
If you ever have future plans to get more power. In all honesty the 4 cylinder has more upgrades available and cheaper than the 3.0. The 2.3 lima has a HUGE race following with parts. But you say you just want a DD that gets mileage and can still offroad. With the right gears (which it should already have) it's gonna be your best friend.
The 3.0 is a great reliable engine but it's not powerful and has an odd powerband for a truck. It does have more hp and torque than the 2.3 but it makes it at way higher rpm.
