Which camber alignment bushings should I get?
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
If interested I have these new in box. I'll send them to you for 40.00 .
Not trying to make money just don't have a use for a lot of stuff that I bought over the years.
Sold! Pm me
86isuzu
TRS Member Since 2003
Firefighter
EMT / Paramedic
ASE Certified Tech
9
Eden, NY
Ford Bronco II
2.9L
2"
31"
Threadjack!
I also installed leveling coils. '89 BII, Skyjacker 132. I took it to my mechanic who is pretty well versed in ttb suspensions with 2.5 & 3.5 degree camber bushings. He says it isn't enough to align it yet and suggested drop brackets. I feel if I have to install drop brackets, I may as well just put on a proper 4" lift. Unless there's a milder drop bracket option out there.
This just doesn't sound right...
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Threadjack!
I am eventually gonna go legit lift as well, but with cut and turned arms, for I have heard drop brackets are a no no (they cause the front pumpkin to hit).
There are drop bracket options out there, but none are proper.
I ordered a set of 3 degree bushings to try out. even it its still not enough, its better than degrees. I figure frequent tire rotations will get me by for now.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
forgot to m
Threadjack!
Forgot to mention I have seen 4 degree bushings out there, maybe one more degree will bring it into spec?
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
You can have this thread lol, I already ordered some...haven't installed them yet, but will let you know how it goes....
I've got a set of new spring pads to install as well while I'm in there...and tlc the wheel bearings.
ericbphoto
Overlander in development
16,594
Wellford, SC
6"
86isuzu
Firefighter
EMT / Paramedic
ASE Certified Tech
9
Eden, NY
Ford Bronco II
2.9L
2"
31"
Only certain brands
Right. Skyjacker and James Duff are ok.
I don't think .5 degree is gonna be enough to work. There's gotta be something I'm missing.
franklin2
1,758
Virginia
You can't lift one of these suspensions by just using the springs. That's it. 1.5 inches you can do and expect to be able to align it. But of course 1.5 inches isn't enough for most people. Some people have gotten 2 inch spring only lifts straightened out, but that probably depends on the vehicle and depends on "how close" they wanted it aligned. Being "close enough" is sometimes good enough for some alignment techs.
86isuzu
Firefighter
EMT / Paramedic
ASE Certified Tech
9
Eden, NY
Ford Bronco II
2.9L
2"
31"
Right. I did the 2" coils, which only netted me 1.5 ". So I should be able to align it without issue. That's the confusing part.
Locotomb
62
Puyallup, WA
2.3l
6inch custom fab lift/86
Bagged 3 inch custom drop beams 88/89 Custom triangulated and step notched rear
35/12.5/r18
Everything looks better lower
I finally got the brackets done. All I need to do now is The text file.
rumblecloud
1,120
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
I know this is old, but it is exactly what I was looking for-- especially the TRS magazine link to an article by 4x4junkie
