which ball joint do I get?
wrangler8
I have a 93 ranger, 4x4, xlt and I need to replace lower passenger side ball joint. however I have a dana 28/35 hybrid front axle. I dont know wether I need to get a ball joint for dana 35 or 28.
swynx
9
lewiston idaho
Mazda
35 housing 28 guts. Id go with 35s. And get good ones. Top and bottom...
lil_Blue_Ford
6,129
Butler, PA, USSA
4.9L
With the exception of the housing for the gears, the inner axle shafts, and the guts inside the front pumpkin, it is a D-35 in all respects. Even the U-joints for the axle shafts are the same as a D-35. So you will need D-35 ball joints. Brakes, U-joints, bearings, spindles, ball joints, etc are all D-35.
I feel like this is a topic that has been covered to great extent.
swynx
9
lewiston idaho
Mazda
I'm pretty Sure tthis entire subject is covered in the tech section
wrangler8
Ok thanks everybody.
