Where can I find code 89 axel.
Nax6401
Utah
Ford Ranger XLT
30 x 9.5 R15
I am trying to build a 4x2 ranger as an off road truck and I have gotten bigger tires. I have on now 30 inch tire and feel no power in 5th gear.. my first thought is to swap in a different axel or at least the gears.. I am trying to find axel code 89 and was wondering if anyone knew what vehicles had it installed so I can go pull one from the junk yard.
Dirtman
13,322
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
If you are referring to the 4.56 geared axle, good luck. It was a unicorn and I've yet to find anyone who's actually seen one.
Nax6401
Utah
Ford Ranger XLT
30 x 9.5 R15
I'm trying to find the 4.10 so I guess also that axel code 87
15,637
SW Iowa
Dead or dyin' 4cyl 4wd.
4.10 is sorta commonish in second gen Explorers if you are up for an axle swap...
Nax6401
Utah
Ford Ranger XLT
30 x 9.5 R15
Do you think that the 4.10 is okay for the 30 inch tires I have? I have axel code 84 right now but I just want something that is a little easier since I know that I would have to swap the whole axel of I wanted the 4.10 since it is also a disc brake rather than drum
Dirtman
13,322
41N 75W
It's up there.
It's down there.
Round.
4.10 is extremely common. In both 4wd and 2wd trucks. My 09 2wd has 4.10 (code 87). 4.10 will be ok with 30" tires. Definitely a huge improvement over 3.45 gears. The ideal axle would be to look for an F7 though for the limited slip, or even better an R7 which is the larger 8.8 4.10 limited slip.
Nax6401
Utah
Ford Ranger XLT
30 x 9.5 R15
I was planning on putting in a locker while I was changinf
dvdswan
2,570
Seattle, WA
Ranger XLT 2WD
If you are going to use a Lock-Rite locker find one with an open diff then.
7,743
Welcome to TRS :)
For off-road you want an R7 code, limited slip 4.10
Full time Lockers are not good for street use and worse in snow and icy conditions
Limited slip is the way to go, IMO, they are lockers that allow "slipping" when you go around a corner, a "locker" will drag or push one wheel when cornering because both axles HAVE TO turn at the same speed, which is great when driving in a straight line, but sucks when going around a corner, lol
Nax6401
Utah
Ford Ranger XLT
30 x 9.5 R15
I guess I am going to go with the R7 axel then.. what are they most common in.
Dirtman
13,322
41N 75W
It's up there.
It's down there.
Round.
Most common in 4x4 rangers with the 4.0 engine.
Nax6401
Utah
Ford Ranger XLT
30 x 9.5 R15
So for me to swap it would I need to replace the whole rear axel then or just the gears in the case?
Dirtman
13,322
41N 75W
It's up there.
It's down there.
Round.
If you get an F7 (7.5") you could just swap gears and carrier but you'd still need to buy a new install kit (bearings, shims, crush sleeve etc etc) and swapping gears is not just a bolt in process, you need special tools, take precise measurements, make adjustments. It is MUCH easier to swap the entire axle, in which case you could get an R7 (8.8").
7,743
Nax6401
Utah
Ford Ranger XLT
30 x 9.5 R15
If I swapped the stronger 8.8 in would I need to change anything on the transmission side of things? I want to make sure that when I go to the junk yard that it's a one stop trip for parts
