what are the rules at McCaslin mountian
Below are the official rules, however when I went there they didn't check anything on my truck. The only thing they said was no alcohol on the trail and I should head back out by 10 pm. Very laid back place and GREAT wheelin...
Steering & Linkage
Steering box and linkage can not be loose when turning steering wheel.
Brakes & Lines
Must have front & rear brakes. Lines must be secured to the axle and/or frame. Peddle cannot be spongy or sink to floor, brakes must have pressure.
Roll Bar/Non-Removable Hard Top
Vehicle with full removable top must have roll bar securely mounted. Vehicles with altered body/chassis/drive train combinations are required to follow roll bar rules as stated for removalbe hard top. (Examples of altered body/chassis/drive train combinations are S10 Pickup on full size chassis, old style Bronco on full size Bronco frame, etc.) Basically, any vehicle body that was not factory built to handle a roll-over with the additional modified weight will require additional roll bar protection for it's occupants.
Exhaust System
Must have mufflers attached to engine, no open headers or staight pipes. ONly stock mufflers, no glass packs.
Tire Size/Lug Nuts
Maximum tire size is 40 inches. Must have ALL lug nuts.
Seats
Must be securely mounted to body.
Seat Belts
Must be properly anchored. Must be worn by all passengers. Child seats/protection required as mandated by state law.
Suspension System & U-Bolts
No threaded rod for U-Bolts. No suspension damage. No lift blocks between front axle houseing and front spring.
Battery Mount
Must be O.E.M. style or equivalent. No wire,rubber or nylon straps allowed. Battery must not move.
Additional Safety Features
Floorboards must be able to protect passengers from bodily injury. No visible fluid leaks on vehicle. No antennas ove 48 inches.
