Wheel specs the same for Bronco - F150?
Mhfco6
Firefighter
87
Virginia
2.9
Are the offset, lug pattern, and bore size the same? I'm looking at a set of Ford aluminum Alcoa style 15'' from a 1994 Bronco. Will they fit my 87 F150? The front shaft seems to stick out past the wheel, further than my F150. May just be missing the cover.
Ranger850
Doesn't get Sarcasm . . .
4,687
Tallahassee Florida
Stock 2"
Stock
AFAIK, The Bronco frame is a shortened version of the F-150 frame, so wheels/rims should fit.
Mhfco6
Firefighter
87
Virginia
2.9
I've been reading and found that all ford trucks are 5x5, with the exception of a few trucks in the 80s. I thought mine were 5x5.5
ericbphoto
Overlander in development
16,548
Wellford, SC
6"
Up to a certain year, maybe and not including Rangers and Bronco II's and maybe Explorers which are generally 5 x 4.5. My 97 F150 is 5 x 135mm and then some newer trucks started using 6 lugs and, I believe I have seen or heard of 7 lugs. Newer trucks are confusing.
racsan
4,420
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
pre-97 F150 & bronco to 96 are 5 on 5-1/2. there were some early 80’s F100’s that were like a ranger (5 on 4-1/2.) so those would work for you. 97& up F150 I have no clue but think they went to 17’s and metric pattern anyways. The light duty F250 (1997?) was a one-year 7 lug wheel.
(5 on 5 is a chevy 1/2 ton & astro pattern)
2drxploder
434
usa
ranger
347
lower
235 on 15s
yes i put 150 wheels on my 82 bronco before big tires
Mhfco6
Firefighter
87
Virginia
2.9
Just figured out how to properly do this. Looks like I have 5x5.5. Thanks.
snoranger
Professional money waster
ASE Certified Tech
13,627
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
This.
Except the 7 lug was used until 03 on the 7700 lb gvw f150 up until 03. 04-08 f150s had the 8200lb gvw 7 lug as an option.
Mhfco6
Firefighter
87
Virginia
2.9
Looking at some American racing 12 holes off a 77 truck. Center hole is 4.25 but mine is 3.5. Seems like too much a difference. And it was a 2wd truck, so the locking hubs won’t work from my truck either. If anyone knows anything about this hit me up. I’m supposed to go pick these up tomorrow. I can mount them lug centric but still might not mount up okay.
I think they will work, just won’t be able to use my beauty ring. The hub is separate from the wheel.
snoranger
ASE Certified Tech
13,627
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
All the standard thread lug f150s are lug centric (All pre-97). As long as the center bore is bigger than your hub, the rims will fit.
pjtoledo
2,959
Toledo Ohio
Fords
3.0 2.3
most aftermarket wheels are lug centric. they work fine with any good quality wheel.
Mhfco6
Firefighter
87
Virginia
2.9
Thanks guys, they fit perfect.
