Wheel specs the same for Bronco - F150?
Mhfco6
13
Virginia
2.3
Are the offset, lug pattern, and bore size the same? I'm looking at a set of Ford aluminum Alcoa style 15'' from a 1994 Bronco. Will they fit my 87 F150? The front shaft seems to stick out past the wheel, further than my F150. May just be missing the cover.
Rock Auto 5% Discount Code: 7FA902352B4C01: April 5th, 2021
Ranger850
1,546
Tallahassee Florida
Stock 2"
Stock
AFAIK, The Bronco frame is a shortened version of the F-150 frame, so wheels/rims should fit.
Mhfco6
13
Virginia
2.3
I've been reading and found that all ford trucks are 5x5, with the exception of a few trucks in the 80s. I thought mine were 5x5.5
ericbphoto
How long did it take me to find this?
Forum Moderator
4,433
Wellford, SC
6"
Up to a certain year, maybe and not including Rangers and Bronco II's and maybe Explorers which are generally 5 x 4.5. My 97 F150 is 5 x 135mm and then some newer trucks started using 6 lugs and, I believe I have seen or heard of 7 lugs. Newer trucks are confusing.
racsan
975
central ohio
2.3/140-4
225/70/15-winter. 235/75/15-summer
built, not bought
pre-97 F150 & bronco to 96 are 5 on 5-1/2. there were some early 80’s F100’s that were like a ranger (5 on 4-1/2.) so those would work for you. 97& up F150 I have no clue but think they went to 17’s and metric pattern anyways. The light duty F250 (1997?) was a one-year 7 lug wheel.
(5 on 5 is a chevy 1/2 ton & astro pattern)
2drxploder
72
usa
ranger
2.5 (4 Cylinder)
stock
235 on 15s
yes i put 150 wheels on my 82 bronco before big tires
snoranger
Forum Moderator
ASE Certified Tech
4,583
Jackson, NJ
'79,'94,'02,'17
All Fords
This.
Except the 7 lug was used until 03 on the 7700 lb gvw f150 up until 03. 04-08 f150s had the 8200lb gvw 7 lug as an option.
Mhfco6
13
Virginia
2.3
Looking at some American racing 12 holes off a 77 truck. Center hole is 4.25 but mine is 3.5. Seems like too much a difference. And it was a 2wd truck, so the locking hubs won’t work from my truck either. If anyone knows anything about this hit me up. I’m supposed to go pick these up tomorrow. I can mount them lug centric but still might not mount up okay.
I think they will work, just won’t be able to use my beauty ring. The hub is separate from the wheel.
snoranger
Forum Moderator
ASE Certified Tech
4,583
Jackson, NJ
'79,'94,'02,'17
All Fords
All the standard thread lug f150s are lug centric (All pre-97). As long as the center bore is bigger than your hub, the rims will fit.
pjtoledo
640
Toledo Ohio
Fords
3.0 2.3
get outta my way, I'm falling!
most aftermarket wheels are lug centric. they work fine with any good quality wheel.
