wheel specs 1989 2wd
DRLUNDIUS
Zion, Illinois 60099 and Mena, Arkansas 71953
Ford / Ranger
99 Ranger is 2.5L automatic, 89 Ranger is 2.9L manual
215R-70-14
Pay attention to details. Quality is not expensive, it is Priceless!
Hello Wheel and Tire forum. 1989 2WD 2.9L Super-cab 125" WB Wheel Size? I need a spare wheel for this old 89 I am fixing up. I just put on new tires. Stock size 215/70R-14, is what the door sticker says. I did not measure the wheel and I do not have a caliper to measure. I will make one if needed. I want to get the exact stock wheel for a spare. I found one but I am not 100% sure of the wheel width. I found a 14" 8 hole steel wheel that is 5.5" wide. Can anyone confirm if it is the correct width. I have found other wheels that say they are 6" wide. I have a 2WD and I think 5.5" is correct. Can anyone confirm?
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I deleted your other post... once is usually all you need. Sometimes just takes a bit to get a response.
Have a look in the Tech Library... there is a pretty complete list of wheels used and their specs.
Ford Ranger Wheel Fitment Guide - The Ranger Station
DRLUNDIUS
Ford / Ranger
215R-70-14
Thank you Uncle Gump, as a newbie I did not see my first post so I wrote another, still getting use to this website. When I did see both of them I could not find a way to delete one. I will take a look at the link. I was hoping someone could tell me if stock 14" wheels for my ranger were 5.5" wide. After further investigation I think the wheel size is on stamp in the door jamb. I just went outside and looked. Tire size and wheel size are right on the vehicle sicker on the drivers door. Thank you you helped me answer my own question.
