eightynine4x4
- Oct 15, 2020
- 196
- New York
- Ford Ranger
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
- Total Lift
- 2.5" Suspension
- Tire Size
- 31 x 10.5 x 15
Hello all,
Yep, drivers front wheel flew off while driving. I had done about 6-7 hours of driving, including highways, to pick up about 1000 lbs of windows and bring them home. I was just 4 miles from reaching home, and was on a small slow road. Got lucky to say the least. I was only doing 25-30 mph and it was at midnight so nobody else was on the road. The wheel rolled about 100 yards straight up the opposing traffic lane until it veered into the shoulder and ditch. It was exactly like a comedy movie would have done it.
After the immediate clunk, and now driving with one of the wheels being a metal disc, i pulled slowly over out of the lanes while watching the wheel roll down the road. I shut down and left the truck on the side of the road for the night and came back the next morning for repair. It was pretty stressful and my lower back is a bit strained but not too much.
The manual hub “cap” section had flown off and cracked off about 50% of its edge sections but the core was ok. After probably 3 hours of navigating getting the truck out of loose gravel and repositioned on flat land, and assessing the state of the rotor lug threads, i lifted it and borrowed 1 lug nut from each of the other 3 wheels and fastened the 4th wheel back on and carefully drove home. I also thoroughly cleaned out the gravel from the rotor/brake sections. I did use the cracked hub because i was unsure of the state of threads the further in i went with the lug nuts since that section of threading had never been used probably. I bolted a triangle pattern with the nuts, focused on the strong areas remaining in the manual hub edge.
Anyways, the lesson is that i need to regularly re-torque my wheels. I had done everything properly in May of 2023, including a follow up re-torque. But this wheel’s lug nuts worked themselves away and off on this special day. Probably because of the extra amount of highway driving i did. Or, maybe i‘m human and when i re-torqued the wheels i skipped that wheel. I’ll never really know. Or, maybe there is just too much gunk / grease on these old rotor stud threads and i didn’t clean them well enough so they gradually all loosened.
I could have easily died from this. If this had happened while going 60+ on the busy highway in the middle lane, it would have been an absolute wreck and made the news.
So now I’m buying a pair of new manual locking hubs. I’d wanted them anyways because one of mine had a nearly non existent handle part so was tough to turn.
And the rotor’s perimeter was smash-flattened in a few spots from dragging on the road briefly, and since I’m buying one I may as well get a pair of new front rotors.
It actually drove home fine without any strain or noises, so I think the brake system, and pads, are fine. But I’ll inspect the pad when i redo the rotor.
My truck is a 1989 4x4 (Manual Locking) Auto-Transmission V6 2.9.
I believe i have the Dana 28 axel but I would appreciate confirmation of that.
Can i just buy a set of manual hubs and pop them right on? Like these?
I see that some manual locking hubs come with more parts, such as the rings with notches in them. Could there be some brand compatibility issue if i pop on these Mile Marker brand ones onto the guts of the “OEM” ones that are still on my truck?
My former lock-hubs are the OEM ford ones I believe. Although, i don’t see “FORD” written on them like some other locking hubs.
This first pic is of my setup, from May 2023, before i did the restoration work to it. The second and third pics are from today.
Dana 28 Mile Marker Lock-Out Hubs, Pair-Broncograveyard.com
Mile Marker D28 Supreme Hubsbr The cure for those stock hubs that never hold up when you need them.br Made using a new process of die-casting aluminum into a pre-made jacket, it provides lightweight, strength and corrosion resistance.br It uses the ultimate combination of materials for the cap...
shop.broncograveyard.com
