Wheel Bearings - Which rotor do I need
Mhfco6
Firefighter
87
Virginia
2.9
That looks like it's for a full float rear end. I don't think it will work for your front bearings. That snout will be in the way.
I think you need PT 648473.
Back to the drawing board. Installed new rotors/races/bearings and noise still exists but ONLY in 4x4. What’s the next thing to check besides gear oil?
Next is to get it on jack stands and run it in 4x4 while you lay under it to figure out where the noise is coming from.
Mhfco6
Firefighter
87
Virginia
2.9
:agree: Wow, thanks soo much for the help! I’m suspecting spindle bearings if nothing internal on the Dana. Do you know where I can get a new spindle seat? Mines rusted up and falling apart. Is it called something else?
http://a66.tinypic.com/34spkpx.gif
black_demon69
142
AZ
4.0l
Try rockauto.com that's where I got mine several years ago
Mhfco6
Firefighter
87
Virginia
2.9
Just thought I’d update.. Spindle bearings were to blame.
