Wheel bearing upgrade
Joel Shields
Edgewater FL
Mazda
2.5
Looking to go from the tapered bearing style to a bolt in hub style. I know that the spindles brakes rotors calipers will also need to change. But what vehicle has spindles that share the same geometry? I just want to simply bolt it in have an alignment and be done with it.
Any help will be greatly appreciated thank you
Joel Shields
Edgewater FL
Mazda
2.5
By the way it is a 1999 Mazda b2500/ranger
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
None of them...
ericbphoto
Overlander in development
16,593
Wellford, SC
6"
That's an expensive project just for "simplicity" . Those things cost a lot to replace compared to traditional tapered roller bearings.
Joel Shields
Edgewater FL
Mazda
2.5
I don't mind the cost they last longer as well as being simpler. It doesn't have to be be a ranger or even a Ford part for that matter. Just as long as it will work. Has anyone tried this at all? If not I guess I'll have one made. Billet aluminum would be cool.
snoranger
Professional money waster
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Why? The stock setup works. I've gone well over 100K miles on the original bearings.
How can you consider it an upgrade? It's more expensive to fix, can't be serviced, usually aren't as strong, etc... sounds like a downgrade to me.
I'll give you that it's simple... unbolt, throw away, bolt in new. That's not including seized in place by rust, though.
JOLENE_THE_RANGER
204
long beach, ca
Short answer No pepboys part will do that.
long ansert. you can get custom spindles made with a 12 bolt snout block from pro am or camburg and then run a 2" or 2.5" aluminum race hub.
snout block
https://camburg.com/shop/drivetrain/camburg-4130-bolt-on-snout-block/
snout
https://camburg.com/shop/drivetrain/camburg-2-50-front-bolt-on-spindle-snouts/
hub
https://camburg.com/shop/drivetrain/camburg-2-50-front-hub-kit-5-on-5-5/
they make a spindle for rangers ready for the hub set up but that spindle is designed to be used with uniballs as the lower and upper arm pivots not ball joints that your stock arms will have.
will cost more than your ranger as a whole. but its what youre looking for and fully serviceable.
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
maybe,, MAYBE,,, you could have a shop press the bearing spindle stub out and find a way to install one from a 1998 Crown Vic, or some years Mustang.
then see what it takes to align the rotor to the calipers.
Bird76Mojo
1,265
IL
Switching to a unit style bearing over a tapered bearing is NOT an upgrade.
They do not last longer.
My 1988 B2 has it's original factory wheel bearings. You will NEVER find find a unit bearing that goes 250K miles or 31 years.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I have no words to describe how insane this idea is...
8thTon
--- Banned ---
806
Pennsylvania
I can't imagine wanting to switch away from adjustable, greaseable tapered bearings to press-in cartridge bearings.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Guy must be a former jeep Cherokee owner.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Or radically hates packing bearings
sgtsandman
Aircraft Fuel Tank Diver
12,641
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The pressed in sealed bearings you are looking for can last as long as tapered roller bearings but you have to buy quality bearings (not parts super store bearing like AutoZone or Pep Boys), they have to be installed with a press and the proper bearing plate, and a few maintenance "secret" tips for best results. BUT the expense of doing the conversion so you can use such bearings is just not plain worth it. I'll take tapered roller bearings over a pressed in bearing any day. If it ain't broke, don't fix it.
No members online now.
