BigMeatyClaws
- Nov 18, 2020
- 7
- TrStat1776
- Ford Ranger
1985 with feedback 2150a carb. I have a stalling issue at the beginning of acceleration. The engine stalls like it is going to die then picks back up if I stick with it on the gas. I also have knock under load. Timing is good. Accelerator pump and diaphragm are good. Power pump is good. Appears to be running rich per black exhaust. No idle issues, except the idle air mix screws don't seem to be very sensitive to change. New coil, wires, plugs, and distributor cap. 22 hg vacuum and steady. What would you check next? Float level? Battery voltage? Back up light fuse?
Many thanks
Many thanks
