What parts to salvage from Explorer, and Sport Tracs for application in my B3000.
gaz
706
Wa, Bremerton 98310
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
@bhgl
I think the coolest feature on a Sport Trac is the auto lower/raise rear window...I want one!
Ranger850
Doesn't get Sarcasm . . .
4,806
Tallahassee Florida
Stock 2"
Stock
Thanks @don4331 for explaining. I wasn't sure about some stuff. Just thought I would throw the Rotor thing out there. I didn't pay attention to his YM or the year range that the swap would work on. Sorr IF I added confusion to the convo.
bhgl
232
Northern Ontario, Canada
Mazda B3000
Update on the junkyard suspension component finds:
I wasn't able to grab anything for suspension this trip, main focus being on some seats, some miscellaneous plastic/good-to-haves and an e-fan.
04 Explorer Sport Trac Front Sway bar:
It's pretty big, 1.2 Inches as measured with a caliper, and it seems the bushing and end links on this particular truck were done rather recent! I may try to salvage them to save a few bucks since they look less than a year old. It's kinda sad to see, but someone clearly loved this particular truck.
Rear Sway Bar from other Ford Ranger:
No luck in this department, there was one sway bar equipped ranger, I believe a 2006, but between the rust and the fact it was an 8.8, I wouldn't have been able to salvage almost any of the fasteners/brackets/ubolts, and I would have spend enough hours cleaning it up I'd probably be better off just ordering something online, we'll keep looking though.
JoshT
2,191
Macon/Fort Valley, GA
I can say with 99.9% certainty that the 4.0L coil will not work on the 3.0L. We had a 2000 3.0L Ranger for about a year that my cousin gave us for.parts thinking it had a bad transmission. It wasn't a bad transmission, but a combination of bad coil, bad fuel pump, and needing a tune-up. I'm almost certain that our spare 4.0L coils.wouldnt fit, but we still had Mom's old 3.0L Taurus in the back yard. We fixed cheap, and flipped cheap to someone that needed a truck.
I'm pretty certain I've seen explorer/sport trac roof racks modified to a Ranger cab. It certainly wouldn't be a bolt on mod.
Edit: Oops, I thought this comment said cap, not cab. I haven't personally seen one on a Ranger cab, but I could see it being cut down to fit an extended cab as @sgtsandman said below.
Yes, the roof rack can be mounted on a camper shell. Seen it done several times and I've thought about doing it myself if I can find a decent ARE shell around here. I'll be saving the one off my donor explorer just in case. IMO the Mountaineer rack looks a little better, but the Explorer rack is probably more functional. Either would work for me since it probably wouldn't carry more than a canoe or kayak.
Not discounting the Explorer skid plates, but I'm not sure about fitting them. The Explorer frame (96+ at least) is wider than the Ranger once you get aft of the front suspension. Might work, but might also be too wide.
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
13,338
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
They can be modified to work on a cab roof too. Not much utility on a regular cab but is of some use on a Supercab.
Though, the roof of the bed cap would indeed make more sense, unless you are carrying something long. I put racks on both the cab and the cap if I'm carrying a canoe or long building materials.
No members online now.
TexasDuck66
July Truck of The Month
